FJuan Posted December 23, 2007 Share Posted December 23, 2007 Just notice today when I was checking out my headlights that the pass. side bulb was dimmer than the driver side. Or that the driver side is much brighter than the pass. side. I'm still using the stock bulbs on a 2005 LGT. Possible problems? 1) One of the bulbs is slowly going out? 2) Headlights need to be realign? 3) Power shortage in one of the lamps? Anyone had the same problem before? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
FJuan Posted December 24, 2007 Author Share Posted December 24, 2007 Nevermind, found the problem. The dim bulb was not seated right in the housing, causing it to point down toward the ground. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
