Hanger Posted December 21, 2007 Share Posted December 21, 2007 Here's some pictures of the dilema right now.... http://legacygt.com/forums/showpost.php?p=1573644&postcount=98504 1. Coilovers on, same height set all around 2. (From the softest) 12 Front , 14 Rear and it's still rubbing 3. Driver rear has always been like that, looks as if the axle isn't straight? pushing the wheel to towards the front more 4. Passenger rear is fine, but minimum rubbing if go over big bumps, driver side is the worst Gonna raise the car up maybe half an inch tonight and see how it'll go Wish me luck! Raise the rear up to 2 finger gap... and we found out what was the problem with the rubbing.... Seller messed up with the offset... IT'S FREAKING et35 instead of 18x8 et 45 :eek::mad: it no longer rubs in the rear... but now i have to figure out if i want to run 35 offset wheels... any pros and cons? or i'll consider getting my refund ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
Hanger Posted December 21, 2007 Author Share Posted December 21, 2007 What will i be entitled for reimbursement? This is the money i've spent just to get this wheel on... 1. $$$ Wheels 2. $80 for dismount from my Rota, and mount/balance on the new wheel 3. $80 for cut both rear fender 4. $80 for dismount from the new wheel, and mount/balance back on the Rota and? 5. Emotional distress? ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
DiscoWagon Posted December 21, 2007 Share Posted December 21, 2007 Wheel bearings!!! I personally would return them and get my money back if he will allow it. Link to comment Share on other sites More sharing options...
Blue GT Posted January 12, 2008 Share Posted January 12, 2008 KEEP THEM, it doesn't rub anymore and now it appears I know what i need to do to run that offset. Link to comment Share on other sites More sharing options...
Xenonk Posted January 12, 2008 Share Posted January 12, 2008 spend lots of money on fender flaring and spend even more money on getting better suspension components, and then get ready to replace wheel bearings from time to time. Keefe Link to comment Share on other sites More sharing options...
Hanger Posted January 14, 2008 Author Share Posted January 14, 2008 YUP! I hear you! traded them with 18x7.5 +45 over the weekend. Gonna run with 5mm spacer and push them out to +40 ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
ProjectS15 Posted January 17, 2008 Share Posted January 17, 2008 +38 Link to comment Share on other sites More sharing options...
