BDII Posted December 19, 2007 Share Posted December 19, 2007 have a good recipe? Post it up! Me: Slum 1 pound elbow macoroni 1. Pound ground beef 2 Green peppers 1 vidalia onion 1 can condensed tomato paste (small) 1 can stewed tomatoes Italian seasoning Garlic, fresh ground Boil pasta to 3/4 cooked fry hamburg with diced green peppers and onion and a 2 teaspoons of minced garlic Sprinkle italian seasoning on top of hamburg, mix. Drain pasta, stir in stewed tomatos (don't drain) and tomato paste, mix add hamburg mix. stew for onlow for 30 minutes, mixing regualry feeds up to 6. Garnish with a New England bulky roll and margarine or butter. sprinkle parmesan cheese if you so desire. Cooking time: 40 minutes Cost: $20 at the most. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Guest Gitster Posted December 19, 2007 Share Posted December 19, 2007 Trying to find one of my recipes Link to comment Share on other sites More sharing options...
BDII Posted December 19, 2007 Author Share Posted December 19, 2007 Appetizer: 1 bag of soft pita's 1 ball of fresh Mozzerella 3 fresh tomatoes 1 stick of fresh basil 1 bottle italian vinegrette dressing slice up the pita into triangles Slice the cheeze into 1/5th inch slices slice up the tomato dice the Basil Put the chees on top of the pitas, then tomato, then sprinkle with basil Bake at 300 until the cheese melts. remove, fill a small bowl with vinagrette, dip and enjoy! Feeds 4 Time: 20 minutes Cost: $15-30 (market dependant) Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
PeterJMC Posted December 19, 2007 Share Posted December 19, 2007 Just what I needed... Better than my frozen food lunches. They should actually just be called frozen flavored salt, 80%+ of your daily sodium intake... :-O Link to comment Share on other sites More sharing options...
-TT- Posted December 19, 2007 Share Posted December 19, 2007 "Firecrackers" Invented by Jedimaster Per Firecracker you need 1 ritz Cracker 1 Pinch of High Grade Nug 1 spoonfull of Peanut butter To Prepare: 1. Spread peanut butter on Ritz cracker. 2. add nug. 3. heat in microwave to your liking 3. enjoy! Several variations will work, be creative. Link to comment Share on other sites More sharing options...
BDII Posted December 19, 2007 Author Share Posted December 19, 2007 Here's another one for you health concious peeps (calorie diets) 1 pound boneless chicken breast 1 box white rice 1lb bag mixed veggies Mrs Dash butter seaoning (0 calories 0 fat) 1 bottle LIGHT italian dressing Remove fat from chicken, Marinate chicken overnight in dressing. Boil 1/2 pound of rice, cook marinated chicken on George foreman grill. Boil veggies. Drain veggies and sprinkle mrs dash on, also sprinkle on rice. Mix rice and veggies, serve with chicken breast. Feeds 3 Time: 20 minutes Cost $10-$15 Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
BDII Posted December 19, 2007 Author Share Posted December 19, 2007 "Firecrackers" Invented by Jedimaster Per Firecracker you need 1 ritz Cracker 1 Pinch of High Grade Nug 1 spoonfull of Peanut butter To Prepare: 1. Spread peanut butter on Ritz cracker. 2. add nug. 3. enjoy! Several variations will work, be creative. wowowowowowoww!!!!!!!! you need to heat the peanut butter so that the oils in the peanut butter bind with teh oils of teh green vegatative matter otherwise known as Marijauna Your body will not process all the oils from weed... it needs to be lifted off the plant and binded with a food oil. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Guest Gitster Posted December 19, 2007 Share Posted December 19, 2007 Cheesy Spinach Artichoke Dip. 1 French baguette (sliced) 2 cans artichoke hearts 1-2 bags baby spinach leaves fresh 1 med/small onion (diced) 3-4 cloves garlic (dice/chopped) Flour for Roux Olive oil / butter 1 carton chicken stock Cheese (grated) 1-3 cups each Monterrey Jack Mozzarella Cheddar Muenster Chile Powder / salt / pepper for seasoning Start with large pot / dutch oven saute garlic and onion in half olive oil butter, just enough for the amount of onion/garlic. Always season in stages, once they start to cook, use a little salt/pepper/ chile powder. Once tender, not dark, start sprinkling flour slowly and whisk together as to not lump. One table spoon at a time. Once all the liquid is absorbed by flour, cook flour for 30 seconds to a minute, not letting it burn or darker too much. Add 4-5 cups of chicken broth slowly to Roux. Whisk in so flour does not clump. Bring to a boil and then reduce heat to a simmer to thicken. Meanwhile, drain canned artichokes and rough chop. Remove and wash spinach. Set aside. Once reduced by a third, bring heat to low and add cheese stirring slowly. Once all melted, add spinach, stir til wilted. Add artichokes. Mix well, serve hot ! Use Baguette to dip ! 20 Minutes, $20. I make it differently everytime. The key it to have the proper amount of liquid to cheese to get the right consistency. You cant add heat once you add the cheese or it will seperate, so be careful. The amounts of cheese to broth mixture is not accurate, you have to play with it everytime, or reduce the liquid by more, so the mixture is less or more cheesey than you need Link to comment Share on other sites More sharing options...
-TT- Posted December 19, 2007 Share Posted December 19, 2007 wowowowowowoww!!!!!!!! you need to heat the peanut butter so that the oils in the peanut butter bind with teh oils of teh green vegatative matter otherwise known as Marijauna Your body will not process all the oils from weed... it needs to be lifted off the plant and binded with a food oil. edited. i thought i was missing that. Link to comment Share on other sites More sharing options...
Guest Gitster Posted December 19, 2007 Share Posted December 19, 2007 Whatd you edit Link to comment Share on other sites More sharing options...
BDII Posted December 19, 2007 Author Share Posted December 19, 2007 the heat eliment Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Guest Gitster Posted December 19, 2007 Share Posted December 19, 2007 Oh I thought TT edited your post. He edited his own Link to comment Share on other sites More sharing options...
-TT- Posted December 19, 2007 Share Posted December 19, 2007 Oh I thought TT edited your post. He edited his own ^retard Link to comment Share on other sites More sharing options...
Guest Gitster Posted December 19, 2007 Share Posted December 19, 2007 ^retard Well you quoted a post and said Edited Link to comment Share on other sites More sharing options...
Guest Gitster Posted December 19, 2007 Share Posted December 19, 2007 Asshat Link to comment Share on other sites More sharing options...
Penguin Posted December 19, 2007 Share Posted December 19, 2007 Here's a fool proof one. One 750ml bottle of 100 proof (50% alcohol by volume) bottle of Knob Creek bourbon whiskey. One glass. One ice tray. Fill glass with ice. Add bourbon whiskey. Sip beverage until empty. Repeat as needed or until desired affect is achieved. Link to comment Share on other sites More sharing options...
Guest Gitster Posted December 19, 2007 Share Posted December 19, 2007 These are the bomb: Thai Chicken Burgers Add everything, and then fry a small sample to test the seasonings on the burgers, and add more in if needed. Use the relish on the burger if you like it spicy, top with the coleslaw. Thai chicken burgers 2 lbs ground chicken 2-3 cloves of garlic, squished thru garlic press dry peanut sauce mix—1/4 cup? Bottled Peanut sauce –1/4 cup? Sesame oil Soy sauce Garlic salt Scallions Chopped water chestnuts Cilantro Form into patties and spray both sides with Pam. Grill. Serve with pineapple Cole Slaw and onion/hot pepper relish Cole slaw Cole slaw mix Rice wine vinegar Mayonnaise Cilantro Fresh pineapple, cut into small pieces Dash salt Onion/hot pepper relish Minced onion Minced hot peppers Lime juice Olive oil salt Link to comment Share on other sites More sharing options...
BDII Posted December 20, 2007 Author Share Posted December 20, 2007 Bu11dogg2's killer pork chops 2 lbs fresh porkchop (on bone) 1 jar minced garlic or fresh minced garlic 1 bottle Virgin Olive Oil 1 bottle italian seasoning Coat frying pan and chops in olive oil and sprinkle with garlic and seaoning. Open window or turn on fan Fry until done. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
axis008 Posted December 20, 2007 Share Posted December 20, 2007 dont forget to post pics!! -ben Link to comment Share on other sites More sharing options...
