spartan0199 Posted December 10, 2007 Share Posted December 10, 2007 Hello I have a 2003 Legacy Sedan and I noticed that in the manual it says you should not rotate the tires left to right. I usually change my own oil and rotate my tires at that time. For all my other cars (RWD or FWD) I rotate front to back and left to right. I'm not clear on why you couldn't rotate the tires left to right on this car? I understand that you want even wear on all the tires, that makes sense to me. Link to comment Share on other sites More sharing options...
MGV101 Posted December 10, 2007 Share Posted December 10, 2007 Most radial tires are only designed to spin in one direction. If you put them on the other side, they would be spinning in the wrong direction. Unless you plan to drive in reverse of cause. Link to comment Share on other sites More sharing options...
spartan0199 Posted December 10, 2007 Author Share Posted December 10, 2007 Yes you right some tires are directional and should not be moved left to right. In this case it is not the tires. When I open the tire paperwork that came with the car it states that the tires can be rotated left to right but to refer to the owners manual. I assume Subaru does not want the tires rotated left to right because of the AWD system, just wondering if anyone has more detail on why that would be. Link to comment Share on other sites More sharing options...
chenc544 Posted December 10, 2007 Share Posted December 10, 2007 The only thing on the AWD system that I can think of is the center diff but I don't see how rotating tires left to right would matter. You will always want to rotate your tires front to back regularly so they wear evenly and stay at about the same diameter. This helps with the wear and tear of the center diff but I don't think rotating left to right would make any difference... Link to comment Share on other sites More sharing options...
STG Posted December 10, 2007 Share Posted December 10, 2007 I've spoken with an engineer at Bridgestone regarding the OEM tires on my 2005 LGT. There is no reason you have to keep them on one side of the car. The OEM tires are not unidirectional. Link to comment Share on other sites More sharing options...
MGV101 Posted December 11, 2007 Share Posted December 11, 2007 hahaha... sorry, forgot you guys in the states get the crappy RE92 as OEM tires. We get the RE050 here! Link to comment Share on other sites More sharing options...
STG Posted December 12, 2007 Share Posted December 12, 2007 hahaha... sorry, forgot you guys in the states get the crappy RE92 as OEM tires. We get the RE050 here! How much does a new Legacy GT (2.5 turbo) cost in Hong Kong? :lol: Link to comment Share on other sites More sharing options...
