smack Posted December 8, 2007 Share Posted December 8, 2007 Does the ebay borla replica header fit if the rest of the exhaust is stock? and if so does it have a noticeable tone? i searched around and couldnt find anything. Link to comment Share on other sites More sharing options...
MonkeyHermit Posted December 8, 2007 Share Posted December 8, 2007 This has been discussed in other threads already, but I'll save you the time. The Borla headers, replica or not, will only be bolt on for the 05 2.5i's. For 06+ 2.5i's the header design was changed so you'll need to get a custom cat section in order to use the Borlas. To extract the true Boxer Rumble from theses headers though, you'll need to either get new axle backs or new cat back system. Most have done Borlas to custom cat then custom piping back to usually Magnaflow mufflers. If you search around, you'll find a number of threads containing this info. Link to comment Share on other sites More sharing options...
smack Posted December 9, 2007 Author Share Posted December 9, 2007 thanks... ended up finding a lot of info on it like you said, just searched for the wrong info. guess im going with the prodrive mufflers instead for my first exhaust work Link to comment Share on other sites More sharing options...
