gary_gnu Posted December 5, 2007 Share Posted December 5, 2007 After reading the thread about people having a clogged/leaking drain tube behind the radio/glovebox area, I was feeling the behind the carpet in that area and found a green connector that was disconnected. One side has a red wire, the other side is blue/black. Anyone know what the purpose of this connector is? Should I reconnect it or just leave it? I bought this car used last month, so I don't know it's history on stuff like that. Link to comment Share on other sites More sharing options...
PhilT Posted December 5, 2007 Share Posted December 5, 2007 Nooooooooooo ! Don't connect the green plugs !!! That's the self destruct connectors Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
BDII Posted December 5, 2007 Share Posted December 5, 2007 After reading the thread about people having a clogged/leaking drain tube behind the radio/glovebox area, I was feeling the behind the carpet in that area and found a green connector that was disconnected. One side has a red wire, the other side is blue/black. Anyone know what the purpose of this connector is? Should I reconnect it or just leave it? I bought this car used last month, so I don't know it's history on stuff like that. They are supposed to be unplugged. You only connect these to do diagnostics or changing base maps with an Access port. check out this thread http://legacygt.com/forums/showthread.php?t=5888 and most importantly, this thread: http://legacygt.com/forums/showthread.php?t=67940 Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
tommypenguin Posted December 5, 2007 Share Posted December 5, 2007 After reading the thread about people having a clogged/leaking drain tube behind the radio/glovebox area, I was feeling the behind the carpet in that area and found a green connector that was disconnected. One side has a red wire, the other side is blue/black. Anyone know what the purpose of this connector is? Should I reconnect it or just leave it? I bought this car used last month, so I don't know it's history on stuff like that. Those are the test wires brother, not supposed to be connected while your driving. I was an idiot last week and uninstalled my AP from my car but left those connected. Start my car and my check engine light is flashing, never had that happen before, took a drive around the block before i realized I never disconnected my AP after the uninstall. Oops. Link to comment Share on other sites More sharing options...
BDII Posted December 5, 2007 Share Posted December 5, 2007 ^ did that once too talk about scared Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
