weaselslegacy Posted November 24, 2007 Share Posted November 24, 2007 I have a 97 LGT just had the tranny swapped out and is working ok I guess but to the real meat of this point. This morning I went for a drive everything working as it should. Then later this evening I got in and it would not start. just like a dead battery. So I jumped it off and as soon as I turned on my headlights the whole car just killed out. All Lights out everything. When the system reset the alarm was going off and will not crank. does anyone have any idea's what might be going on. The only thing I can think of is possibly a bad ground???? Link to comment Share on other sites More sharing options...
meier motor sports Posted November 24, 2007 Share Posted November 24, 2007 could be a bad ground. id check the battery and charging system out too Link to comment Share on other sites More sharing options...
weaselslegacy Posted November 25, 2007 Author Share Posted November 25, 2007 I found the positive wire going to the starter was burnt up and also a bad ground to the battery. Link to comment Share on other sites More sharing options...
