Deal of the day.
andrew.anderson
This thread useful to anyone???
151 members have voted
  1. 1. This thread useful to anyone???
    • Yes.
      118
    • No.
      33
  • Replies 819
  • Created
  • Last Reply
Top Posters In This Topic
$17.99
CP Technologies LevelOne WBR-5400 MIMO Wireless Broadband Router - 4 x 10/100Base-TX, 1 x 10/100Base-TX - IEEE 802.11b/g - Wireless Broadband Router
http://ak.buy.com/db_assets/prod_lrg_images/933/202592933.jpg
Management Windows UtilityWeb Based Management
Interfaces/Ports =
4 x RJ-45 10/100Base-TX Auto MDI/MDI-X LAN
1 x RJ-45 10/100Base-TX Auto MDI/MDI-X WAN
Input Voltage =
12 V DC Device
Wireless Technology =
IEEE 802.11b/g
Manufacturer Part Number =
WBR-5400
Antenna 3 x 5dBi Detachable
Manufacturer Website Address = www.cptechusa.com
Security PEAPDMZ HostVirtual ServerDos DetectionNAT firewall with SPI modeVPN pass through (IP Sec, PPTP, L2TP)
Antenna Range = 115 ft to 656 ft Indoors Approximate
328 ft to 1312 ft Outdoors Approximate
Dimensions =
1.06" Height x 3.94" Width x 5.55" Depth
Certifications & Standards = CEFCCIEEE 802.1xIEEE 802.11iIEEE 802.11bIEEE 802.11g
Frequency Band/Bandwidth =
2.4 GHz IEEE 802.11b/g ISM Band North America
$24.99
BT-300 USB 2.0 to IDE/SATA Adapter
http://images10.newegg.com/NeweggImage/productimage/12-156-102-02.jpg
Spec Type document.write(neg_specification_newline('USB to IDE&SATA')); USB to IDE&SATA Specifications document.write(neg_specification_newline('Works with 2.5", 3.5" HDD, 5.25" CD/DVD Drive and SATA Drives
OS:
Microsoft Windows 98SE/ME/2000/XP
Mac OS 9.2 or higher
Linux 2.4.X')); Works with 2.5", 3.5" HDD, 5.25" CD/DVD Drive and SATA Drives
OS:
Linux 2.4.X Features Features document.write(neg_specification_newline('USB 2.0 to IDE/SATA Cable
Connect any device with an IDE/SATA Interface to a PC with USB interface
Transfer rate Approx. 480 MBps
Complies with USB 2.0 standards
Backwards compatible to USB 1.1 standards
Complies with ATA/ATAPI-66 Spe. V1.0
Easy to Install
Supports IDE/SATA and enhanced IDE hard drives
Supports ATA/ATAPI/SATA CD-ROM/R/RW DVD-ROM and more
External power adapter for IDE/ATAPI/SATA devices
Linux, Mac compatible')); USB 2.0 to IDE/SATA Cable
Easy to Install
Linux, Mac compatible Packaging Package Contents document.write(neg_specification_newline('USB 2.0 to IDE/SATA Adapter
Power Cord
Power Adapter
Driver Disk')); USB 2.0 to IDE/SATA Adapter
Power Cord
Power Adapter
Driver Disk
$384.00
http://www.geeks.com/imageshare/N/150x150/NC6000-8B-unit.gif
HP Pentium M 1.6GHz 512MB 40GB CDRW/DVD 14'' XP
Features/Specifications:
* HP nc6000 Intel Pentium M 1.6 GHz Notebook
* Grade B (see below for description)
* General Features:
* Microsoft Windows XP pre-installed w/COA
* Intel Pentium M 1.6 GHz processor
* 512 MB RAM
* 40 GB hard drive
* CD-RW/DVD-ROM drive
* SD memory card reader
* Integrated video
* Integrated audio w/built-in speakers
* Integrated modem
* Integrated 10/100/1000 Base-T Ethernet
* Keyboard with touchpad
* 14-inch TFT display with 1024 x 768 maximum resolution
* Li-Ion battery pack
* Expansion Slot:
* Two (2) Type II and one Type III PC card slot
* I/O Ports:
* One (1) 15-pin VGA connector
* One (1) 9-pin serial port
* One (1) 25-pin parallel port
* One (1) S-Video
* Two (2) USB ports
* One (1) RJ-11 phone jack
* One (1) RJ-45 Ethernet jack
* One (1) Port replicator
* Microphone and headphone jacks
* Regulatory Approvals:
* FCC
* CE
* CSA
* UL
* TUV/GS
* Gost-R
* Semko
* BSMI
* VCCI
Package Includes:
* HP nc6000 Pentium M 1.6 GHz notebook
* AC adapter (100-240V, 50/60 Hz)
* Power cord
be careful of b-grade components!
Good advice. Read the listing though. No Grade B components. THe laptop condition is grade B meaning=
Notebook is in very good condition
Has Cosmetic Blemishes, examples of which are (but not limited to):
Scratches in case
Scratches in the screen
Hairline crack in case
Dead pixels (5 or less)
Missing doors
May be missing manual, drivers, operating system, carrying cases
Battery is not guaranteed to hold a full charge
Battery is not covered under warranty
All specific issues will be noted in the ad
Etc.
FREE (4.99 shipping)
i-rocks IR-4100 4-ports Aluminum USB Silver Hub - Retail
http://images10.newegg.com/NeweggImage/productimage/17-201-601-02.jpg
Spec:
Type: USB
Standards: USB 2.0/1.1
Ports: 1 x Upstream, 4 x Downstream
Transfer Rate: 1.5/12/480Mbps
Power Input: Bus-Power: 5V 500mA / Self-Power: 5V 2.5A
Adapter: Input: 100~240v 50Hz-60Hz / Output: 5V 2.5A
Dimensions: 3.2" x 1.3" x 0.5"
Temperature: 0° C~ 40° C
Packaging:
Package Contents IR-4100
Power Adapter
USB Cable
Samsung LN-T4661F 46" LCD HDTV with Integrated ATSC Tuner - 1080p - 10000:1 Dynamic Contrast Ratio - 8ms Response Time - Black - LNT4661FX/XAA
List Price: $2,799.99Our Price: $1,399.99Shipping: $75.00Buy.com Total Price: $1,474.99
http://www.buy.com/retail/product.asp?sku=204222893&adid=17654&dcaid=17653
Samsung FP-T5084 - 50" Widescreen 1080p Plasma HDTV w/ ATSC/NTSC Tuner - 15000:1 Contrast Ratio
List Price: $3,499.00Our Price: $1,949.99Shipping: $75.00Buy.com Total Price: $2,024.99
http://www.buy.com/retail/product.asp?sku=204709042&adid=17654&dcaid=17653
$179.99
Acer AL2216WBD 22" Widescreen LCD Monitor - Ultra-fast 5ms, WSXGA+ 1680x1050, DVI, VGA, Black, VESA 100mm
http://images.tigerdirect.com/skuimages/large/Acer-AL2216WBD-A179-2204.jpg
Specifications
Display Type: TFT LCD
Viewable Screen Size: 22 inches
Pixel Pitch: 0.28 mm
Input Video Signal: 15-pin D-subDVI-D
Contrast Ratio: 700:1
Brightness: 300 cd/m²
Response Time: 5 ms
Horizontal Viewing Angle: 170 degrees
Vertical Viewing Angle: 160 degrees
Maximum Resolution: 1680 x 1050
Cabinet Color: Black
VESA Mounting Compliant: VESA 100mm
Unit Dimensions (WxHxD): 20.2" x 16.0" x 7.8"
Unit Weight: 12.3 lbs.
Power Consumption: 55W
:) i misread how the thread was meant. it took me a minute to figure out that it was only deals you were posting, not deals of the day for random people to post
If you find a great deal, post it here.
You should start a "Grayson Subaru: Deal of the Day" thread with dealson subaru stuff. I would subscribe.
