Andreu Posted November 15, 2007 Share Posted November 15, 2007 I was wondering if i could use an access port to setup a fuel map and timing settings to be lower then stock for an economical mode, like the spec b has. Or do i just have to get a utec and do it? Link to comment Share on other sites More sharing options...
Jon in CT Posted November 15, 2007 Share Posted November 15, 2007 Complete your profile, with the car you own and your location. Link to comment Share on other sites More sharing options...
tractorcrusher Posted November 15, 2007 Share Posted November 15, 2007 AccessPort merely just plugs in... There's nothing for you to program Link to comment Share on other sites More sharing options...
Scotty Posted November 15, 2007 Share Posted November 15, 2007 AP can already do that. Link to comment Share on other sites More sharing options...
Bbc84 Posted November 15, 2007 Share Posted November 15, 2007 of if you have SI-Drive just put it into I Link to comment Share on other sites More sharing options...
Andreu Posted November 15, 2007 Author Share Posted November 15, 2007 of if you have SI-Drive just put it into I My gt dosent have the SI swith i wanted to put one in aftermarket. Link to comment Share on other sites More sharing options...
JABBER Posted November 15, 2007 Share Posted November 15, 2007 AP can already do that. +1 FYI I notice a very minimal gain in fuel economy between I mode and sport. Link to comment Share on other sites More sharing options...
Brady Posted November 15, 2007 Share Posted November 15, 2007 The best modification you can make to improve gas mileage is the serial link between your brain and your right foot. Keep acceleration easy and steady, stay out of boost, and you can easily attain a 10% or greater increase. That's all the "I" mode does in SI drive - reduces throttle input. The AP does some other tricks in Economy by more or less minimizing the amount of boost you can build, but really, it's a moot point if you just drive nice and easy. The advantage of that is that if you still want to get the most out of the car, all you have to do is make a very simple adjustment ... to your right foot. The other thing you can do is stay vigilant about tire pressure. Especially if you choose to run the tires a little firmer. Link to comment Share on other sites More sharing options...
Ronin Spec. B Posted November 15, 2007 Share Posted November 15, 2007 Brady's correct. I or Intelligent mode just changes the ecu mapping so that you have reduced throttle responses. It's not going to show you noticeable gains in mpg. Driving in I mode will probably get you runover too since it reduces your throttle inputs in an effort to save petrol. Link to comment Share on other sites More sharing options...
Bbc84 Posted November 15, 2007 Share Posted November 15, 2007 In my 08' LGT I mode seems to limits throttle and boost. I just installed my premium prosport gauges, and had it record the peaks when Im driving in different modes. WOT in I mode through 1st to 3rd gear from a stop = 6-7psi of max. WOT in S or S# mode through 1st to 3rd gear from a stop = ~14psi of max. Link to comment Share on other sites More sharing options...
