VtspecB Posted October 30, 2007 Share Posted October 30, 2007 I torqued the head off of one of the screws that holds the heat shield to the bracket that is mounted to the DP. I suspect that all the heat cycles and too much *umpf* caused the failure, particularly too much *umpf*. It is the screw that is closest to the firewall, underneith the I/C. With only 2 screws now holding the HS on, I've now got a slight HS rattle that us perfectionist can't live with. What is the easiest most economical way to extract the remaining screw shaft from the nut that is welded to that bracket? I'd prefer not to remove the DP and bracket, which would be a sure way to get it out. my vBGarage Link to comment Share on other sites More sharing options...
meier motor sports Posted October 30, 2007 Share Posted October 30, 2007 any part of the bolt sticking out? or is it broken flush? are any part of the treads sticking out the other side? could try a vise grip on the exposed threads to work the bolt out. or drill a piolet hole and use an extractor if flush. or just take the other bolts off and remove the heat sheild Link to comment Share on other sites More sharing options...
mwiener2 Posted October 30, 2007 Share Posted October 30, 2007 plasma cutter My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
meier motor sports Posted October 31, 2007 Share Posted October 31, 2007 tnt? Link to comment Share on other sites More sharing options...
Gator GT Posted October 31, 2007 Share Posted October 31, 2007 trade the car in. Get another. Tell them the bolt was defective. "If we are to guard against ignorance and remain free, it is the responsibility of every American to be informed." - T. Jefferson Link to comment Share on other sites More sharing options...
VtspecB Posted October 31, 2007 Author Share Posted October 31, 2007 Flush, threads exposed that have gone through the nut Soaked it with PB blaster and attempted the vise grip on the rear exposed threads, no go. Pilot hole and extracter are the only way to go. my vBGarage Link to comment Share on other sites More sharing options...
robinlsb Posted October 31, 2007 Share Posted October 31, 2007 Flush, threads exposed that have gone through the nut Soaked it with PB blaster and attempted the vise grip on the rear exposed threads, no go. Pilot hole and extracter are the only way to go. Try using a propane or map gas torch. Heat up the area around the exposed threads then try the vice grips. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
VtspecB Posted October 31, 2007 Author Share Posted October 31, 2007 Ahh, excellent suggestion ... thank you. my vBGarage Link to comment Share on other sites More sharing options...
