rayeve Posted October 23, 2007 Share Posted October 23, 2007 Hi to all, I recently installed a couple of new front speaker in my 05 GT (they were Infinity Model: REF6022I). However, this weekend I noticed the front speakers were no longer working. (The rears are okay). This includes not only the ones in the front doors, but also the ones in the window posts. Anyone have any theories on what might have caused this? I don't want to open the doors up if the problem is just a plug on the back of the radio, or if the amp section (stock) itself has somehow failed. All suggestions gratefully appreciated. Ray Link to comment Share on other sites More sharing options...
OGG Posted October 24, 2007 Share Posted October 24, 2007 Check the obvious first. Did you accidentally fade it to the rear? Link to comment Share on other sites More sharing options...
fzanetti Posted October 24, 2007 Share Posted October 24, 2007 Check the obvious first. Did you accidentally fade it to the rear? :lol: Flavio Zanetti Boston, MA Link to comment Share on other sites More sharing options...
rayeve Posted October 24, 2007 Author Share Posted October 24, 2007 I checked the fader -- and everything else in sight. No joy there. Ray Link to comment Share on other sites More sharing options...
Meltdown07 Posted October 24, 2007 Share Posted October 24, 2007 Might be a wiring problem,subaru harness colors aren't industry standard colors, they use a messed up color scheme. Did you rewire up the window post ones too? Because those typically feel off the OEM speakers. Go Cardinals! Link to comment Share on other sites More sharing options...
rayeve Posted October 24, 2007 Author Share Posted October 24, 2007 But that may be a helpful comment. I thought if the doorpost speakers were on separate wiring from the door speakers then the problem had to be near the amp/radio. But if they feed off the door speakers, then it could easily be an issue inside the doors themselves. Thanks. Link to comment Share on other sites More sharing options...
gfxdave99 Posted October 26, 2007 Share Posted October 26, 2007 You would be wise to invest in a $10 voltmeter from radio shack If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
FJuan Posted October 27, 2007 Share Posted October 27, 2007 Here's my cheat sheet for the '05 - '06 models. Maybe this might help. http://www.legacygt.org/forums/attachment.php?attachmentid=158&d=1183705006 My wife's balls are delicious. Link to comment Share on other sites More sharing options...
