hmoob_gt Posted October 16, 2007 Share Posted October 16, 2007 Ok, i know there is probably a thread of this somewhere in this forum, but i couldnt find exactly what i was looking for. What i want to know is, which set up of front sway bar with endlinks and rear sway bars with endlinks kit is better. my choices im looking into so far is the COBB KIT, CUSCO KIT, or the AVO KIT. so if anyone knows which one is an easier fit and better for the money, let me know. Thank you! Link to comment Share on other sites More sharing options...
Buru Posted October 16, 2007 Share Posted October 16, 2007 Depends on what other mods you have, or plan on having Link to comment Share on other sites More sharing options...
hmoob_gt Posted October 16, 2007 Author Share Posted October 16, 2007 Ok, I Am Planning On Getting A Stage 2 Package Only. With An Front Mount Intercooler. With Maybe An Upgrade Turbo. Nothing Big. But Im Waiting For The 07 Tuning Program To Come Out First. But I Want To Run Something That Will Still Be Useful After The Mods. Link to comment Share on other sites More sharing options...
chenc544 Posted October 16, 2007 Share Posted October 16, 2007 Ok, I Am Planning On Getting A Stage 2 Package Only. With An Front Mount Intercooler. With Maybe An Upgrade Turbo. Nothing Big. But Im Waiting For The 07 Tuning Program To Come Out First. But I Want To Run Something That Will Still Be Useful After The Mods. Depends on what other mods you have, or plan on having Suspension mods, not power mods. Link to comment Share on other sites More sharing options...
Buru Posted October 16, 2007 Share Posted October 16, 2007 bump Link to comment Share on other sites More sharing options...
whitetiger Posted October 16, 2007 Share Posted October 16, 2007 perrin 25mm f+R FTW. And AVO endlinks to keep it stock style. Link to comment Share on other sites More sharing options...
hmoob_gt Posted October 16, 2007 Author Share Posted October 16, 2007 Ok, So A Mix Match Is Better? Link to comment Share on other sites More sharing options...
Buru Posted October 17, 2007 Share Posted October 17, 2007 not neccesarily Link to comment Share on other sites More sharing options...
Wales Garage Posted October 17, 2007 Share Posted October 17, 2007 cusco with avo links Link to comment Share on other sites More sharing options...
hmoob_gt Posted October 17, 2007 Author Share Posted October 17, 2007 hmmm, looks like everyone mostly chooses the AVO endlinks. lets see, what if i get the AVO kit that comes with the sways, links and enforcers? has anyone done this route? Link to comment Share on other sites More sharing options...
Buru Posted October 17, 2007 Share Posted October 17, 2007 not me Link to comment Share on other sites More sharing options...
hmoob_gt Posted October 17, 2007 Author Share Posted October 17, 2007 Well, Not Everyone, But Seems Like The People Whos Helping Me With The Decision Is Choosing Avo Endlinks. What Do You Choose? Or Prefer? Link to comment Share on other sites More sharing options...
Buru Posted October 17, 2007 Share Posted October 17, 2007 I have not looked into it as much as i should, but it think that i would like to keep to a not very stiff bar, like cobbs to let the coil overs i want (the tein flex's) do their job. Link to comment Share on other sites More sharing options...
hmoob_gt Posted October 17, 2007 Author Share Posted October 17, 2007 hmmm, never thought about it. Link to comment Share on other sites More sharing options...
Buru Posted October 17, 2007 Share Posted October 17, 2007 Start to read around the suspension sticky. I want a handling machine so I am going with the tein flex to get the stiffness. A proper coilover setup does not need that stiff of a swap. Plus really stif rear sway can make you oversteer more. Link to comment Share on other sites More sharing options...
rexster Posted October 17, 2007 Share Posted October 17, 2007 sway bars on stock shocks/springs still sucks. sure there's a little less lean side to side. but the car is twitchy at the limit and still has way too much front/back movement. if you go this route make sure you get the rear sway bar reinforcement brackets, you'll need them. Link to comment Share on other sites More sharing options...
hmoob_gt Posted October 17, 2007 Author Share Posted October 17, 2007 ok, i guess when it comes down to it. too stiff makes the car have over steer, and not stiff enough gives it over steer, so im guessing, as for me right now, i might go with the AVO kit or maybe the 22mm perrin front and rear with AVO endlinks? the 25 is too stiff right if your still running stock suspensions? Link to comment Share on other sites More sharing options...
rexster Posted October 17, 2007 Share Posted October 17, 2007 ok, i guess when it comes down to it. too stiff makes the car have over steer, and not stiff enough gives it over steer ??? Oversteer is when the back end begins to break free first. this can be caused when the rear is proportionally stiffer than the front. if you put a bigger rear bar on without a matching front, or stiffer rear springs and struts without matching fronts. this will become even more apparent in the rain and snow when traction is much lower. if you do both front and rear bars it will remain more balanced and be less likely to drastically alter over/understeer behavior. most larger bars are designed to be used in conjunction with stiffer struts and springs which is why people bend the rear mounts. Link to comment Share on other sites More sharing options...
Neurodancer Posted October 17, 2007 Share Posted October 17, 2007 Haven't seen this anywhere else, so I thought I'd throw my chips in here. I just had Cobb F&R Sways & Endlinks installed on my 08 today. My tuner told me that he was surprised about how much of the suspension was reworked with the new MY -- 05-07 coilovers will not fit the 08 for example. I was surprised to hear about this as I hadn't noticed anything about it on LGT.com. The OP should be okay as he's in an '07, but others should be warned to ensure that they don't buy something that won't fit. Link to comment Share on other sites More sharing options...
Buru Posted October 18, 2007 Share Posted October 18, 2007 How if this is true i have never heard about it either. Link to comment Share on other sites More sharing options...
BDII Posted October 18, 2007 Share Posted October 18, 2007 I busted both my AVO endlinks... I DO NOT reccomend them. go Whiteline sways with cobb ends. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Buru Posted October 18, 2007 Share Posted October 18, 2007 I like the way the cobb ends look. I will probably go with all perrin stuff. It will be the thin sways. ~22mm Link to comment Share on other sites More sharing options...
hmoob_gt Posted October 18, 2007 Author Share Posted October 18, 2007 ok, maybe i can go perrin all the way around. hmmmm??? Link to comment Share on other sites More sharing options...
Buru Posted October 18, 2007 Share Posted October 18, 2007 That is what I would do. I plan on ordering mine from King of Parts, they have great prices and I have used them before and everything went smoothly. Link to comment Share on other sites More sharing options...
hmoob_gt Posted October 18, 2007 Author Share Posted October 18, 2007 ok. thankss. Link to comment Share on other sites More sharing options...
