warnoldscu Posted December 10, 2004 Share Posted December 10, 2004 Does the 2.5i have the same shifter as the GT? Has anyone put a short throw in their i? Link to comment Share on other sites More sharing options...
NonovUrbizniz Posted December 24, 2004 Share Posted December 24, 2004 Yes they're the same... at the very least there is a factory sub. ss for the i... I'm 99% that they're the same though. Link to comment Share on other sites More sharing options...
SBT Posted December 24, 2004 Share Posted December 24, 2004 I'm not sure since the transmission case has been redesigned/fortified on the LGT and this could require different shifter mount points or re-routed linkage to compensate for the LGT's case redesign. You would really want to check with a parts guy to make sure. However, that said, here's a quote from [url="http://www.1stsubarparts.com"]www.1stsubarparts.com[/url] on the 2005 Legacy STK: "The STi short throw shifter significantly reduces shift-throw lengths for crisper shifts and sportier driving. Fits all 2005 Legacy models except 3.0L Outback's". So, one would be lead to believe that it would work for both the LGT and Li. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
