shaggy Posted December 8, 2004 Share Posted December 8, 2004 I was in a friends car last night with acc and it doesn't blow any air until it heats up, is this the way the GT is supposed to work? Mine blows full bore cold air right away, is something wrong or is it just another acc sucks problem? Link to comment Share on other sites More sharing options...
DSattler Posted December 8, 2004 Share Posted December 8, 2004 Mine blows cold air right away as well. My wife's Toyota Sienna waits until the engine starts to warm up and then blows warm air, which is the way ACC should work. Subaru has something to learn about ACC, I think. Link to comment Share on other sites More sharing options...
Hatt Marrington Posted December 8, 2004 Share Posted December 8, 2004 mine blows cold at the lowest possible rate, then the fan speed increases as the engine warms up and the warm air is available. -Hatt 2005 Obsidian Black Legacy GT 5MT Un-Limited Sedan Link to comment Share on other sites More sharing options...
foerster Posted December 8, 2004 Share Posted December 8, 2004 On auto, mine won't turn on until the temp gauge is up 1/8 to 1/4 (almost to the first break line). If it's on defrost, it'll start immediately to try to clear the windshield. Edited: Well, ok, as the previous post mentions, it may be on at the lowest level (when on auto), I'd have to check, but certainly not very noticable until it warms up... Link to comment Share on other sites More sharing options...
SBT Posted December 8, 2004 Share Posted December 8, 2004 Question for you owners since mine's not arrived yet - Can you set the "auto" to "off" and set the system to "recirc" so you 1) don't have any fan and 2) don't get outside air until you're ready (the car's warmed up and you want fresh air)? SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Nick Posted December 8, 2004 Share Posted December 8, 2004 [quote name='Subietonic']Question for you owners since mine's not arrived yet - Can you set the "auto" to "off" and set the system to "recirc" so you 1) don't have any fan and 2) don't get outside air until you're ready (the car's warmed up and you want fresh air)? SBT[/QUOTE] Yes. Link to comment Share on other sites More sharing options...
sduford Posted December 8, 2004 Share Posted December 8, 2004 [quote name='DSattler']Mine blows cold air right away as well. My wife's Toyota Sienna waits until the engine starts to warm up and then blows warm air, which is the way ACC should work. Subaru has something to learn about ACC, I think.[/QUOTE] I have many issues with the ACC, but this is not one of them. Either you are not in full AUTO mode or your system is defective. The 05 ACC when in AUTO mode doesn't start blowing air until the engine has warmed up into the normal range. It's actually the only time I use the AUTO mode; as soon as it gets near the desired temp, I switch to semi-auto. Sly Sylvain www.digitalfotographer.com - Audi Q5 Club - MB-GLK Club Link to comment Share on other sites More sharing options...
c_hunter Posted December 9, 2004 Share Posted December 9, 2004 Yep Sly is right. Before the engine warms up in cold weather, it should switch to defrost mode and turn the fan off so that no air is being directed towards passengers. Once the engine warms up enough to crank out heat, it will switch to floor or bi-lev and heat the cabin. Craig Link to comment Share on other sites More sharing options...
shaggy Posted December 9, 2004 Author Share Posted December 9, 2004 Thanks folks, back to the dealer. Link to comment Share on other sites More sharing options...
Kuth678 Posted December 13, 2004 Share Posted December 13, 2004 In defense of subaru on this one, I think they did it right. Yeah it might be a bit cold to start, but it IS removing the moisture from the front window. My impreza is the same (although no ACC). Safer in my opinion, more important than being a bit uncomfortably cold for a minute or two. Link to comment Share on other sites More sharing options...
