BlackOnBlackGT Posted September 24, 2007 Share Posted September 24, 2007 I am confused if this is a normal thing? My 5mt sits higher in the front (5 finger gap) as opposed to my friends AT(4 finger gap) Is this normal? Due to the heavier weight of a A/T or is my car just weird. Will this be effected when I get springs ie; will it sit higher than it's supposed to or will springs fix this? Anyone have input? Link to comment Share on other sites More sharing options...
TRS Posted September 24, 2007 Share Posted September 24, 2007 Could be the extra weight of the AT, or if the at is older more settling, or just variation during production, or any combination of these. My left rear gap has always been a little less than the right rear and some others have noticed the same on their car. Link to comment Share on other sites More sharing options...
BlackOnBlackGT Posted September 24, 2007 Author Share Posted September 24, 2007 both 08 he got his a day after mine I have more miles. I dunno, I am just hoping that once I lower it, it doesn't stay like that or a ffect it Link to comment Share on other sites More sharing options...
IBLIS Posted September 24, 2007 Share Posted September 24, 2007 it's most likely the weight of the AT. My srt-4 was lower at the passanger side front wheel due to engine weight. Only thing that cured the problem was a set of coilovers. Link to comment Share on other sites More sharing options...
Guest Posted September 24, 2007 Share Posted September 24, 2007 The stock springs are different between MT and AT to compensate for weight difference. Maybe your car has AT springs...? Link to comment Share on other sites More sharing options...
BlackOnBlackGT Posted September 25, 2007 Author Share Posted September 25, 2007 The stock springs are different between MT and AT to compensate for weight difference. Maybe your car has AT springs...? That seems very unlikely unless Subaru fucked up from the factory Link to comment Share on other sites More sharing options...
pillboy Posted September 25, 2007 Share Posted September 25, 2007 Trucks have manual transmissions, and everyone knows trucks sit higher than cars. It is still ugly. Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted September 25, 2007 Share Posted September 25, 2007 AT weighs more so therefore....... Link to comment Share on other sites More sharing options...
Guest Posted September 25, 2007 Share Posted September 25, 2007 That seems very unlikely unless Subaru fucked up from the factory Not unheard of. They can forget put bolts on turbo, so they can put wrong springs. Compare color codes on the front springs with your buddy's car - if they are the same, that's wrong. Ideally find someone with an MT car and compare with his/hers. You could have also gotten 3.0R springs which I would guess are different as well. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted September 25, 2007 Share Posted September 25, 2007 As unclemat pointed out, the nominal spring rate for ATs is higher than for the MTs. Theoretically, Subaru accounted for the weight difference. However, springs aren't that accurate. Assume +-10%. What would that range be in inches? Link to comment Share on other sites More sharing options...
