outback07 Posted September 22, 2007 Share Posted September 22, 2007 would it be fine to use the spare tire well wall to huk the ground wire for my amp ??? or where wud u prefer Link to comment Share on other sites More sharing options...
str8dwn Posted September 22, 2007 Share Posted September 22, 2007 I put mine there toward the back bumper. If you can, get one of the JL Master Ground Lugs instead of a plain bolt. Really did a professional job. Link to comment Share on other sites More sharing options...
Mark34 Posted October 14, 2007 Share Posted October 14, 2007 Just remember, if you're using a bolt hole that is with a painted surface, make sure to scrape the paint off to to get the best ground. Link to comment Share on other sites More sharing options...
CTATV Posted October 15, 2007 Share Posted October 15, 2007 Just remember, if you're using a bolt hole that is with a painted surface, make sure to scrape the paint off to to get the best ground. 2nd that Link to comment Share on other sites More sharing options...
