OBXT Swaybar question
Box1813
I've done the research: I know the LGT swaybars fit the OB just fine with stock hardware.
Now, I know the swaybar will be on my car by the end of the year. If I get the MR coilovers and drop the car down will this mess with the swaybars? Do I need adjustable endlinks? (I'm planning on going as low as I can without rubbing)
I've gone to cobb sways front and rear, with the stock endlinks on MR OB Coilovers with no problem. If you want to drop the car as low as possible, I would get the regular coilovers (ones for the LGT) the body is shorter and will allow the car to be dropped more (although you may need alignment aids afterwards...)
