sgeorge Posted September 24, 2007 Author Share Posted September 24, 2007 Yes it was WOT, and it happened between 5-6k rpm. I cleared the code and am waiting for it to happen again. Link to comment Share on other sites More sharing options...
joe tom Posted August 12, 2008 Share Posted August 12, 2008 i know its been a while, but has this occured any more?? the same thing happened to me today, but i also have a really rough idle, and my only power mods are up,dp, street tune. Link to comment Share on other sites More sharing options...
ebondragon87 Posted August 13, 2008 Share Posted August 13, 2008 A blinking CEL happens when you have a severe misfire, usually caused by over fueling, like a stuck open injector. The CEL blinks because damage is being done to your cats and possibly your motor. If you changed your plugs recently with low grade plugs or bosch "performance" plugs I'd start there. Otherwise check your injectors. Link to comment Share on other sites More sharing options...
joe tom Posted August 13, 2008 Share Posted August 13, 2008 A blinking CEL happens when you have a severe misfire, usually caused by over fueling, like a stuck open injector. The CEL blinks because damage is being done to your cats and possibly your motor. If you changed your plugs recently with low grade plugs or bosch "performance" plugs I'd start there. Otherwise check your injectors. thanks for the advice, i replaced the plugs with stock ngk iridiums, so they shouldn't be a problem, but after seeing so many people with injector problems, i'm gonna start there. thanks again. Link to comment Share on other sites More sharing options...
fattymcgee Posted August 29, 2008 Share Posted August 29, 2008 I had a few CEL codes (1518, O2 sensor range low and high) so I reset ECU on my AP. Now do I have to reinstall my stage 1 map since I "reset ECU"? Link to comment Share on other sites More sharing options...
sgeorge Posted September 2, 2008 Author Share Posted September 2, 2008 And the blinking check engine light came back...after we thought it was resolved in may. Same issue as before, stuttering from 4.5-5.5k rpm in 3rd and 4th gear(highway passing on the way back from the beach) Goes back to the dealership tomorrow morning. No power mods at all.... Link to comment Share on other sites More sharing options...
