apexi Posted March 2, 2013 Share Posted March 2, 2013 It sounds like you need #8 and #9 in the image below? If so.. #8 Part number - 909130117 #9 Part number - 909130118 And actually you probably just need #9, but I'll leave part number for #8 there in case what that snaps into got busted too. I'm pretty sure I had to replace that same piece myself after I ran over some retread awhile back. I think it was a large white rivet and a white ring that the rivet snaps into. **Update. It looks like I was mistaken. And I'm confused as well. Based off the image in the ebay link, i think you need part number 5. I don't know why the images display different parts? But when you look at the images in the second picture i attached, part number 909130118 is exactly what I think you need, except mine was white and not black. http://www.ebay.com/itm/SUBARU-909130117-GENUINE-OEM-FACTORY-ORIGINAL-ROCKER-MOLDING-CLIP-/150947047373?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item23252527cd Link to comment Share on other sites More sharing options...
surolegga Posted March 2, 2013 Share Posted March 2, 2013 It sounds like you need #8 and #9 in the image below? If so.. #8 Part number - 909130117 #9 Part number - 909130118 And actually you probably just need #9, but I'll leave part number for #8 there in case what that snaps into got busted too. I'm pretty sure I had to replace that same piece myself after I ran over some retread awhile back. I think it was a large white rivet and a white ring that the rivet snaps into. **Update. It looks like I was mistaken. And I'm confused as well. Based off the image in the ebay link, i think you need part number 5. I don't know why the images display different parts? But when you look at the images in the second picture i attached, part number 909130118 is exactly what I think you need, except mine was white and not black. http://www.ebay.com/itm/SUBARU-909130117-GENUINE-OEM-FACTORY-ORIGINAL-ROCKER-MOLDING-CLIP-/150947047373?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item23252527cd Thanks for the reply! All confusion aside, the part you are referring to is the right one as far as I can tell. I can see from my other intact rivet that I do not need the "base" of the rivet (which is also white on my car) just the rivet itself, which is black. Thanks again. Link to comment Share on other sites More sharing options...
