Mr. CentralOhioSubarus Posted September 10, 2007 Share Posted September 10, 2007 I've had my Autospeed exhaust on my car for several months now and I love it. However, on downshifts it "clunks" against my driveshaft. It's every annoying. I heal-toe, but if I don't get it just right the backlash from the engine drives the exhaust up into the driveshaft. I know that Kartboy long hangers don't fit our exhaust right and tend to fall off. I've been searching for months but I haven't found anything that I can use. Does anyone have any suggestions? Thanks in advance! Link to comment Share on other sites More sharing options...
Mr. CentralOhioSubarus Posted September 12, 2007 Author Share Posted September 12, 2007 Wow, nobody has shopped for exhaust hangers? Link to comment Share on other sites More sharing options...
TRS Posted September 12, 2007 Share Posted September 12, 2007 I'm using Kartboy long poly hangers with my Autospeed catback. The holes do seem bigger, and the welded on Autospeed hangers don't have the knob on the end of them like the stock ones do, but with my setup there's enough tension on the poly hangers to keep everything in place. I haven't had, and don't anticipate the exhaust slipping out of the Kartboy hangers on their own. Link to comment Share on other sites More sharing options...
Mr. CentralOhioSubarus Posted September 12, 2007 Author Share Posted September 12, 2007 Thanks! I might give them a try then. Link to comment Share on other sites More sharing options...
Silverstar Posted September 13, 2007 Share Posted September 13, 2007 Check where your's is hitting. On mine, the mid to s pipe flange was hitting against the driveshaft. I ground that down to give more clearance, then the S pipe was hitting against the driveshaft flange, where it bolts up to the rear diff. A little persausion with a ball peen hammer solved that. Link to comment Share on other sites More sharing options...
