str8dwn Posted September 3, 2007 Share Posted September 3, 2007 Just in a quick search, I found such a wide variety of 5-lug bolt patterns. 5x98, 5x100, 5x108, 5x110, 5x112, 5x114.3, 5x120 and so on. Can someone explain why car manufacturers can't settle on maybe 3 sizes at most? Like 2mm really makes a difference? This way, wheel manufaturers can make more offsets within a given bolt pattern, since they wouldn't have to stock so many different patterns. Also, is there a way to safely change the 5x100 to a 5x114.3 or other more prevalent bolt pattern? The wheel choices for our pattern sucks honestly. Link to comment Share on other sites More sharing options...
CreoSTi Posted September 3, 2007 Share Posted September 3, 2007 The wheel choices for our pattern sucks honestly. What wheel type(s) in particular are you looking for? I've never had a problem finding wheels I liked in the 5x100 bolt pattern... -Mike- Link to comment Share on other sites More sharing options...
Longitude Posted September 3, 2007 Share Posted September 3, 2007 Otherwise change your hubs d0gg Link to comment Share on other sites More sharing options...
EL PAALO Posted September 3, 2007 Share Posted September 3, 2007 We should all be required to drive one of the same 3 vehicles too. There is a huge selection of 5x100 wheels. Even if you swap to 5x114.3 the selection likely won't increase much since scoobies like such high offsets. Link to comment Share on other sites More sharing options...
DrGrip Posted September 3, 2007 Share Posted September 3, 2007 You can run lower offsets on the newer hub bearings... Link to comment Share on other sites More sharing options...
str8dwn Posted September 3, 2007 Author Share Posted September 3, 2007 What wheel type(s) in particular are you looking for? I've never had a problem finding wheels I liked in the 5x100 bolt pattern... -Mike- I've never neen a fan of any of the Konig, Gram Lights, Enkei and others that I've seen on the board. I personally like the Momo GTRs/WRS and Antera 349/363/369 and the AC Schnitzer Type IV. Like the others do it for you guys, these definitely do it for me. Different strokes for diff folks. The problem is that with so many hub patterns the wheel manuf have to stock, they can only produce a certain # of offsets (the most pop ones obviously). And since high offset 5x100 is not popular, we get limited offerings. Longitude: How hard is it to change hubs? Estimated cost? I mean, if I am going to get the wheels I want, and it's reasonable, why wouldn't I switch them out? Link to comment Share on other sites More sharing options...
str8dwn Posted September 3, 2007 Author Share Posted September 3, 2007 You can run lower offsets on the newer hub bearings... Maybe so, but the wheels protrude from the fenders. Antera says a +35 will fit our cars, but I've seen photos on here to the contrary. Link to comment Share on other sites More sharing options...
DrGrip Posted September 3, 2007 Share Posted September 3, 2007 Maybe so, but the wheels protrude from the fenders. Antera says a +35 will fit our cars, but I've seen photos on here to the contrary. They fit on the STi fine, and it doesn't require super crazy fender work. Check out 6gun Racing's STi... Either way...it wouldn't be worth it do to the conversion...the parts involved would total up to be not worth it. There is a bearing upgrade for 5x100 what uses the new bearing with the same 5x100 knuckle that would probably be worth it.. Link to comment Share on other sites More sharing options...
Yukonart Posted September 4, 2007 Share Posted September 4, 2007 WRX sedans and STis have deeper wheelwells . . . hence the bulges. Of course the lower offsets are going to fit them better. Link to comment Share on other sites More sharing options...
pillboy Posted September 5, 2007 Share Posted September 5, 2007 Problem solved... It is still ugly. Link to comment Share on other sites More sharing options...
ivwarrior Posted September 8, 2007 Share Posted September 8, 2007 Longitude: How hard is it to change hubs? Estimated cost? I mean, if I am going to get the wheels I want, and it's reasonable, why wouldn't I switch them out? It's not easy or cheap. It'd probably cost as much as having a set of wheels you like custom made in the size you need. Link to comment Share on other sites More sharing options...
EL PAALO Posted September 17, 2007 Share Posted September 17, 2007 There are plenty of euro style wheels in 5x100. just check out some jdm vip wheels. work and ame should have some. Link to comment Share on other sites More sharing options...
