yuhocheung Posted August 13, 2007 Share Posted August 13, 2007 hi all, i've gone to the garage to install the cusco rear sway and whiteline front sway plus avo endlinks today... the technician said that in order to install the cusco.. they either said they had to move down the downpipe or the muffler... so i said ok... this was in the morning... i dunno if i didnt notice until later or what... whenever i drive over a not-so-deep pothole or manhole... and i'm driving slow... like 40km/h... i hear clanking sound... like metal hitting metal... can anybody diagnose this?... i dunno if this is important but i also have the tein h-tech springs... thanks... Link to comment Share on other sites More sharing options...
Legacy05 Posted August 13, 2007 Share Posted August 13, 2007 What exhaust do you have? My CUSCO RSB fit fine with my stock system and my car was lowered. Are you sure they didn't put it on backwards? Link to comment Share on other sites More sharing options...
yuhocheung Posted August 14, 2007 Author Share Posted August 14, 2007 What exhaust do you have? My CUSCO RSB fit fine with my stock system and my car was lowered. Are you sure they didn't put it on backwards? except for the springs... everything is stock... Link to comment Share on other sites More sharing options...
yuhocheung Posted August 14, 2007 Author Share Posted August 14, 2007 does it fit backwards??? Link to comment Share on other sites More sharing options...
yuhocheung Posted August 14, 2007 Author Share Posted August 14, 2007 alright... somebody tell me if this is fitted backwards... i crouched down to look at the rear sway... and found that the centre of the sway is behind the 2 ends... so let's say from the side view.. my car's front is pointing to the left of me... the rear swaybar from the side would look like "\" ... does anybody get that? plz help!! Link to comment Share on other sites More sharing options...
typeSpeed Posted August 14, 2007 Share Posted August 14, 2007 No, it doesn't fit on any other way. You'll need to shorten the AVO endlinks. If they're the one's I used to have they are adjustable, just shorten them down as much as possible and the sway will stop banging. Silver-Arts.com - Custom web design Link to comment Share on other sites More sharing options...
bobo69 Posted August 14, 2007 Share Posted August 14, 2007 you dont have to move any of the exhaust can you take some pics? Link to comment Share on other sites More sharing options...
G.T.Subie Posted August 14, 2007 Share Posted August 14, 2007 What springs are you running. I have the AVo endlinks and they are adjustable so make sure they match. When I had my H-techs the bar would bang over bumps like you describe. After I installed the Bilstein Struts it went away. Denial is your best friend Link to comment Share on other sites More sharing options...
yuhocheung Posted August 14, 2007 Author Share Posted August 14, 2007 What springs are you running. I have the AVo endlinks and they are adjustable so make sure they match. When I had my H-techs the bar would bang over bumps like you describe. After I installed the Bilstein Struts it went away. i'm running on h-techs right now... the first suggestion i got was make sure the avo endlinks r the tightest/shortest... any other things i can do instead of buying new parts like bilsteins? and should i take it back to the shop and have them move the exhaust/muffler back to stock place? thanks Link to comment Share on other sites More sharing options...
yuhocheung Posted August 14, 2007 Author Share Posted August 14, 2007 you dont have to move any of the exhaust can you take some pics? how should i take the pics? i dun have anything that jacks up the car or nething... i'll try it tomorrow morning... thanks... Link to comment Share on other sites More sharing options...
typeSpeed Posted August 14, 2007 Share Posted August 14, 2007 I had the exact same problem, the issue was resolved by shorting avo's as much as possible. Silver-Arts.com - Custom web design Link to comment Share on other sites More sharing options...
Xenonk Posted August 14, 2007 Share Posted August 14, 2007 just take a pic for us to make it simplier to diagnose for you. it could be attached the longer way by accident. Keefe Link to comment Share on other sites More sharing options...
bobo69 Posted August 15, 2007 Share Posted August 15, 2007 just take a pic for us to make it simplier to diagnose for you. it could be attached the longer way by accident. exactly what i was thinking Link to comment Share on other sites More sharing options...
EJ255_alan Posted August 16, 2007 Share Posted August 16, 2007 I don't actually think u can install the bar the other way around...but who knows...i think u can take a look on the sliver cusco sticker, it should be facing the tail downwards when i did my cusco RSB I did took off the muffler to get better access of the stock RSB as for the sound from bumps...I'm thinking could it be because of the ride height(being too low and not enough upper arm travel so it ended up hitting therbump stop)...b/c i have the same situation with my GT as well, it was lowered by tein flex, the fender gap is around 2 fingers at the back alan Link to comment Share on other sites More sharing options...
NickB34 Posted August 16, 2007 Share Posted August 16, 2007 Are you sure it isn't the front sway bar? I didn't know any other companies besides rallitek had a FSB available for the 2.5i. If they got it in there, they either removed the heat shield or modified it to fit and didn't give it enough clearance. Link to comment Share on other sites More sharing options...
tommypenguin Posted August 31, 2007 Share Posted August 31, 2007 I don't actually think u can install the bar the other way around...but who knows...i think u can take a look on the sliver cusco sticker, it should be facing the tail downwards when i did my cusco RSB I did took off the muffler to get better access of the stock RSB as for the sound from bumps...I'm thinking could it be because of the ride height(being too low and not enough upper arm travel so it ended up hitting therbump stop)...b/c i have the same situation with my GT as well, it was lowered by tein flex, the fender gap is around 2 fingers at the back alan I don't know on the legacy, but when I had my accord, I got in accident and my suspension got messed up. When the shop who was repairing my ride put the sway bar back on, they were able to fit it on backwards, It clunked for a few days and I took it back, they couldn't believe the sway fit, but, it did... backwards, so you never know I wouldn't totally rule that out, but more than likely it just sounds like he needs to shorten up the endlinks. Link to comment Share on other sites More sharing options...
