bgLGT Posted August 12, 2007 Share Posted August 12, 2007 Has anybody found stiffer rear subframe and diff bushings for our car? Any of you vendors willing to fab/test some (Rallitek?) ? I'd love to be able to lose some of that rear end clunk the car makes. Who's interested? Link to comment Share on other sites More sharing options...
LittleBlueGT Posted August 12, 2007 Share Posted August 12, 2007 There are a couple of thread talking about noise issues likely due to wimpy bushings in the rear. I am willing to try whatever may come out, if not I will fab this fall. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
bgLGT Posted August 12, 2007 Author Share Posted August 12, 2007 I was thinking some Delrin inserts would be easy to make when I was putting the AVO RSB brackets on; something similar to the impreza kit. Link to comment Share on other sites More sharing options...
gkstar Posted August 15, 2007 Share Posted August 15, 2007 This might have been covered, but has anyone tried the diff bushing and subframe lock from Whiteline. The subframe locks might line up correctly so that could be an issue, but don't all the 5 spd subies use the same rear diff so in theory the diff bushings should work. Just thinking aloud. Link to comment Share on other sites More sharing options...
bgLGT Posted August 20, 2007 Author Share Posted August 20, 2007 ^^^ I was thinking along these same lines. I emailed Turn in Concepts to see if their Impreza diff/subframe bushings would fit the legacy. They responded that they knew for a fact neither would work but it was something that was on their to-do list. I'm not sure if the whiteline locks would work, but if the TiC diff bushings don't fit I doubt the lock bolts would either. I sure hope somebody makes these things. I feel that one of the major flaws in our cars is simply the overly compliant bushings they have! Link to comment Share on other sites More sharing options...
