wind Posted April 14, 2004 Share Posted April 14, 2004 does the new Legacy use drive-by-wire? does it offer any advantage over mechanical parts??? just curious abou it :roll: Link to comment Share on other sites More sharing options...
SUBE555 Posted April 14, 2004 Share Posted April 14, 2004 The STi has it already as well as the FXT IIRC. It is said to be much better than other systems on the market as I know people who moved up from RS's and other cars to the STi and have noticed little or no impedence with the system. IIRC, it allows the computer to adjust things a little better so everything runs a bit more smoothly and efficiently (every little bit counts), but as I've said, nobody that I know of has noticed negative effects with the system. I cannot remember right now how cruise control is integrated in with the system, but I'd imagine it's computer controlled now. Link to comment Share on other sites More sharing options...
ha-evolution Posted April 14, 2004 Share Posted April 14, 2004 The STi drive-by-wire throttle is awesome! It did not feel or act any differently than a cable actuated setup. The big bonus was that there wasn't a huge throttle cable running across the engine bay and that the cruise setup was much simpler. Link to comment Share on other sites More sharing options...
wind Posted April 14, 2004 Author Share Posted April 14, 2004 so...Legacy uses similar drive-by-waire throttle as STi? is this like LSD that only manual get it or is it also used by auto trans? PS: tell me if i'm asking too much lol :p Link to comment Share on other sites More sharing options...
SUBE555 Posted April 14, 2004 Share Posted April 14, 2004 It's an Electronic Throttle Body, as Troy said it's like using your throttle body, but without the cables. It works independant of any differentials or transmissions. Might want to check out the Tech Info thread. I'll add more info when time becomes available. You can make requests though for more info concerning a certain system though. Link to comment Share on other sites More sharing options...
