Guest *Jedimaster* Posted December 1, 2004 Share Posted December 1, 2004 [quote name='chucktoo'] answer to Jedimaster- should not really be in this thread. [/QUOTE] Whooops- wrong thread. But you could have just answered the question :rolleyes: Link to comment Share on other sites More sharing options...
anotherbrian Posted December 4, 2004 Share Posted December 4, 2004 [quote name='chucktoo']More information on stock suspensions from Service Manual for Outback vs Legacy Yes tire differences are 26.9" vs 24.6" = 2.3 / 2 = 1.15" difference in ground clearance for tires. . . . Now to put 17" x 8.5" on Outback and fix speedo error .[/QUOTE] Is the final gear ratio for the Outback and Legacy the same and the Outback is just running larger diam tires, or are the ratios different to compensate for the bigger tires? I plan to follow a similar route as you with our XT (auto) wagon, so will be tracking your progress. As for fixing the speedo error, if you aren't aware of the Yellow Box ([url="http://www.blackrobotics.com/yb_home.htm"]http://www.blackrobotics.com/yb_home.htm[/url]), check it out. They are commonly used when changing gear sets, and should work just as well for wheel swaps. Link to comment Share on other sites More sharing options...
chucktoo Posted December 5, 2004 Author Share Posted December 5, 2004 Thanks for the lead on YellR box - I asked if it works with on our cars . Outback has final drive ratio of 4.444 the Legacy 4.111 . Link to comment Share on other sites More sharing options...
