Throttlejockey Posted July 25, 2007 Share Posted July 25, 2007 I thought I read somewhere the clock won't display in the left side of the dash by the speedo, only on the navi. The manual states it should get the time from the navi. Should the clock work? Link to comment Share on other sites More sharing options...
ama0787 Posted July 25, 2007 Share Posted July 25, 2007 you will have to go into the navigation settings and tell it you want to display it. I Think you get the option to show temp and date too assuming it is the same as previous navigation units. How do you like the 3.0 compared too your old turbo? Link to comment Share on other sites More sharing options...
Carter Posted July 26, 2007 Share Posted July 26, 2007 Heres the scoop on the 08 2.5 GT with Nav. (not sure about 3.0) I went to the dealer cause the time on the instrument cluster would not display. It took about 30 minutes to figure out. The manual states that the instrument cluster gets its time from the Nav. This is untrue. In order to set the time on the instrument cluster you must turn your key to the ON position (Dont start the car) and hold down the SET button on the steering wheel until the menu options on the instrument cluster show up. You should then be able to figure out how to set the time from there. The only downside ( for me anyway) is the fact that its in military time and there doesnt seem to be a way to change it. Link to comment Share on other sites More sharing options...
Throttlejockey Posted July 26, 2007 Author Share Posted July 26, 2007 Heres the scoop on the 08 2.5 GT with Nav. (not sure about 3.0) I went to the dealer cause the time on the instrument cluster would not display. It took about 30 minutes to figure out. The manual states that the instrument cluster gets its time from the Nav. This is untrue. In order to set the time on the instrument cluster you must turn your key to the ON position (Dont start the car) and hold down the SET button on the steering wheel until the menu options on the instrument cluster show up. You should then be able to figure out how to set the time from there. The only downside ( for me anyway) is the fact that its in military time and there doesnt seem to be a way to change it. Thanks for the info! I'll try it tonight when my wife gets home. Link to comment Share on other sites More sharing options...
Throttlejockey Posted July 26, 2007 Author Share Posted July 26, 2007 How do you like the 3.0 compared too your old turbo? Quite a bit different, still adjusting to the torque difference. It does pull longer where the GT flattened out quick. I think it's pretty close in 0-60 times at least by feel. Handles and stops much better than the 05. Link to comment Share on other sites More sharing options...
Throttlejockey Posted July 27, 2007 Author Share Posted July 27, 2007 Heres the scoop on the 08 2.5 GT with Nav. (not sure about 3.0) I went to the dealer cause the time on the instrument cluster would not display. It took about 30 minutes to figure out. The manual states that the instrument cluster gets its time from the Nav. This is untrue. In order to set the time on the instrument cluster you must turn your key to the ON position (Dont start the car) and hold down the SET button on the steering wheel until the menu options on the instrument cluster show up. You should then be able to figure out how to set the time from there. The only downside ( for me anyway) is the fact that its in military time and there doesnt seem to be a way to change it. Messed with it tonight. I'm stuck on military time also. Was short for time so I didn't look any further. Link to comment Share on other sites More sharing options...
Carter Posted July 27, 2007 Share Posted July 27, 2007 The dealer is supposidly looking for a "fix" on the military time. I cant imagine you cant have a 12 hour clock in the display....A lot of people dont know how to convert, even though its easier than pie. Link to comment Share on other sites More sharing options...
witkiewicz Posted July 31, 2009 Share Posted July 31, 2009 any new findings on changing out of military time? Link to comment Share on other sites More sharing options...
m sprank Posted August 1, 2009 Share Posted August 1, 2009 I figured mine out. The owners manual gave me enough info to figure it out. It does get the time from the nav, in a way. When I changed time zones on the nav or dst settings on the nav the cluster updates about 30 seconds later. Just keep messing with it and read the manual. Worked for me. It also explains how to use the cluster to show memos/reminders like birthdays and aniversaries. Kind of corney, but a feature. Link to comment Share on other sites More sharing options...
