BlackBird97 Posted July 23, 2007 Share Posted July 23, 2007 I was just curiouse how to take appart the center console. I just ordered one of those Harmon Kardon DRive+Plays off of ebay, so I need to start pulling stuff appart. I'm not to familure with how to take appart this car yet. I was wondering if anybody could provide me with a walkthrew or maybe point me in the right direction on how to do this! Thanks guys! Link to comment Share on other sites More sharing options...
Powerman Posted July 23, 2007 Share Posted July 23, 2007 This is a walk through of replacing the cabin air filter. You have to take apart the center console. Don't know if it goes as far as you need, but maybe. http://www.legacygt.com/forums/showthread.php?t=1626&highlight=replace+cabin+filter Link to comment Share on other sites More sharing options...
mikefoy6 Posted July 23, 2007 Share Posted July 23, 2007 Its a lot easier than I thought it would be. 1) take the felt part out of the arm rest. Undo the 2 screws. 2) pull up on the front part to release 2 clips under where the SI drive is (or would be). make sure to pull up on the e-brake so that the leater shroud will slide off. 3) pull up on the shift boot to realse the clips under it (3 or 4 i think) 4) undo the 2 screws that hold the right and left bezel on (by the shifter) 5) pull the bezels straight back (towards the backseat) to release the clips. 6) then you have acess to all the screws that hold the radio & HVAC in... Reverse the steps to put it back together Link to comment Share on other sites More sharing options...
