mikefoy6 Posted February 29, 2008 Author Share Posted February 29, 2008 How do you wire the audio and video wires to the connectors you used? I ordered them from your work. I paid about 20 times the amount to ship them as I did for the connectors themselves. There is only a yellow video connector on the back of the screen, You will have to have some sort of AUX in into the stereo (like the aux input i have in my 08). If you dont have an AUX input to your stereo, I'm not sure how you will get your audio into your speaker. Those connectors you got will have a spot to solder the center conductor, they also have a little ring for the ground (shield) of the wire. Link to comment Share on other sites More sharing options...
08leggy Posted February 29, 2008 Share Posted February 29, 2008 when i go into the hidden mode that displays when ur e brake is up and lights are on it says that the ebrake is not up when it is is the ebrake not hooked up stock to the navi? Link to comment Share on other sites More sharing options...
Kargurra Posted February 29, 2008 Share Posted February 29, 2008 That's correct. It's not hooked up, which is why you can't just pull the brake when you want to change input on the display. When Chuck Norris was born, the only person who cried was the doctor. Never slap Chuck Norris. - E.J.S. Link to comment Share on other sites More sharing options...
mikefoy6 Posted February 29, 2008 Author Share Posted February 29, 2008 It should look something like this, The parking break shows it on even when I'm moving. http://i144.photobucket.com/albums/r182/mikefoy6/IMG_1352.jpg I have an 08 but on some other years may show the parking break in the empty spot on this screen: http://i144.photobucket.com/albums/r182/mikefoy6/IMG_1353.jpg If yours doesn't work, make sure you grounded the right side of the wire, it should be the one that goes to the screen. Link to comment Share on other sites More sharing options...
08leggy Posted February 29, 2008 Share Posted February 29, 2008 nice thanks I'm gonna do the mod this weekend to my I pod I'll post up after pics. Link to comment Share on other sites More sharing options...
ama0787 Posted February 29, 2008 Share Posted February 29, 2008 I have red and white audio inputs going into my stereo. Does anyone know what to do with the wires after I cut the red/white RCA connectors off? TIA, Anthony Link to comment Share on other sites More sharing options...
mikefoy6 Posted February 29, 2008 Author Share Posted February 29, 2008 Does anyone know what to do with the wires after I cut the red/white RCA connectors off? Those connectors you got will have a spot to solder the center conductor, they also have a little ring for the ground (shield) of the wire. the video wire has the main connector to solider the main wire to and the tab on the side for the shielding? Exactly. Link to comment Share on other sites More sharing options...
ama0787 Posted February 29, 2008 Share Posted February 29, 2008 08leggy On the tabs that are on the RCA connectors that the shielding wire from the video goes to. Did you ground any of those tabs or all of them to the chassis? Thanks Again, Anthony *edit* Thanks for the answers to the previous questions. Link to comment Share on other sites More sharing options...
mikefoy6 Posted March 1, 2008 Author Share Posted March 1, 2008 On the tabs that are on the RCA connectors that the shielding wire from the video goes to. Did you ground any of those tabs or all of them to the chassis? You dont need to ground the tabs to the chassis, just make sure they are attached to the shield of the cable. Link to comment Share on other sites More sharing options...
ama0787 Posted March 1, 2008 Share Posted March 1, 2008 Mike, If I have done this before you post I'll put up the answer. Do you remember what size drill bit you used? I am guessing 1/4" or 15/64" Thanks Again I cant wait to be done. I am also putting a sub under the passenger seat at the same time I have to redo the bracket to get it to work. Thanks, Anthony *edit* Looks like a 1/4" bit will do the trick. If it doesn't ill edit again. Link to comment Share on other sites More sharing options...
executor485 Posted March 18, 2008 Share Posted March 18, 2008 I really like your idea of the aux inputs in the bottom of the console... You actually gave me a GREAT idea with that whole setup. I've got a cleansweep on the way, I want 2 aux inputs, one for my sirius and one for the ipod... But it only has 1 set of aux inputs on the cleansweep... So, I'm actually gonna put a pair of the RCA adapter plugs like you have in the console... AND a pair in the cubby. Then I'll just wire them in parallel back to the CS. This way it looks really sharp and I'll be able to remove them all easily. It makes sense in my head, I think... lol... Anyone else have this done or have any ideas/suggestions for me before I do it? If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
moodale Posted December 17, 2009 Share Posted December 17, 2009 Are there RCA audio outputs on the back of the stock HU with NAV on an 08? Link to comment Share on other sites More sharing options...
F-WDC Spec B Posted December 17, 2009 Share Posted December 17, 2009 Nice! Similar to my setup. Link to comment Share on other sites More sharing options...
EquinnoxX Posted December 17, 2009 Share Posted December 17, 2009 Are there RCA audio outputs on the back of the stock HU with NAV on an 08? I know on my 07 there is just a Video input in the back of the navi but you can use the AUX IN in the armrest for audio. You can hook pretty much anything up to it ... http://legacygt.com/forums/showthread.php?t=64698 I just recently redid mine but I still have to come up with a permanent mounting solution. A pic of the work in progress ... http://farm3.static.flickr.com/2547/4192544099_091222d7e4.jpg Link to comment Share on other sites More sharing options...
moodale Posted December 18, 2009 Share Posted December 18, 2009 Thanks for your post, but I am looking for Audio OUT to connect a sub woofer amp. I believe that the connection in the armrest is just Audio IN. There has to be a way to do this with keeping the stock head unit, I just need to figure it out. Link to comment Share on other sites More sharing options...
F-WDC Spec B Posted December 18, 2009 Share Posted December 18, 2009 ^ use a forward an reverse harness to make a t-connector to an LOC. Thats what i did. Link to comment Share on other sites More sharing options...
