wadwizzle Posted July 16, 2007 Share Posted July 16, 2007 hi, this is my first post. my wife drove the legacy down to san diego and after the four hour drive, while using the ac, she found the passenger side floor full of water and could feel it dripping down from in back of the glove compartment. Anyone have any ideas of what might be the cause? Link to comment Share on other sites More sharing options...
mwiener2 Posted July 16, 2007 Share Posted July 16, 2007 Simplest answer is a clogged evaporator drain line. Climb under the car and you should see a small hose hanging down around the back of the front passenger wheel well. I can't remember exactly where it is, but it's under there. Once you find it, take a wet dry vac and use your hand to make up the differences in hose size and try to suck any gunk out. If that doesn't work, take it to the dealer. They can unclog the line and if that's not the problem, the other causes of water leakage are beyond a DIY fix. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
ivwarrior Posted July 16, 2007 Share Posted July 16, 2007 The line's actually pretty easy to get to from inside the car, too. Mine clogged a couple weeks ago, and I couldn't get it cleared from under the hood. Going inside the car, I was able to remove the whole line and while holding my finger over where it came off to keep the water from flooding out onto my floor, I was able to blow through the line to clear it. When I put the line back on, a lot more water came flowing out through it. I can't remember what all I removed, but it only took a few minutes to get to it. The hose is held onto the fitting with a spring clamp. Link to comment Share on other sites More sharing options...
Soda Popinski Posted September 30, 2010 Share Posted September 30, 2010 resurrecting this thread... does THIS look like a clogged line? http://i167.photobucket.com/albums/u148/cherrybloom203/f2bb8025.jpg That's what I found in my car after smelling something funny this morning when I got in it. Link to comment Share on other sites More sharing options...
jton Posted September 30, 2010 Share Posted September 30, 2010 i dunno. thats a lot of water. Link to comment Share on other sites More sharing options...
robbie_R Posted October 1, 2010 Share Posted October 1, 2010 Does it smell like water and not coolant? Looks like someone left the window open. But agreed that's a lot unless you drove a lot with the A/C on full blast. Link to comment Share on other sites More sharing options...
gth5003 Posted October 1, 2010 Share Posted October 1, 2010 I am having the same problem but not even close to the amount of water as in soda's post (#4)...........so I can get to this line from the inside of the car?? I planned on pulling back the carpet that is near the radio and under the glove box to see what I can find tomorrow afternoon. Any other tips locating the evaporator drain line from inside the car?!?! Thanks! Link to comment Share on other sites More sharing options...
gth5003 Posted October 1, 2010 Share Posted October 1, 2010 After doing a little research I found this.............should def help the OP out as well http://legacygt.com/forums/showthread.php/whats-green-adapter-and-water-leaki-113407.html Link to comment Share on other sites More sharing options...
Soda Popinski Posted October 1, 2010 Share Posted October 1, 2010 I found the hose. Take off the inside bottom panel under the glove box with 3 pop-its. The black hose is almost directly back in the corner closest to the firewall and the radio. Problem is, I can't find where it GOES to. It also was getting dark. I'll just put the car on a jack tomorrow and find it outside tomorrow. Edit: it does not look or smell like coolant (I tasted it). The funky smell I was smelling must have been the water built up in the tray under the glove box. Link to comment Share on other sites More sharing options...
gth5003 Posted October 1, 2010 Share Posted October 1, 2010 ok thanks soda...let me know what you find out tomorrow and I'll do the same unless you beat me to it. I found this other thread too http://legacygt.com/forums/showthread.php/water-passenger-footwell-18050.html Soooo many ppl have this problem at 1 time or another it seems Link to comment Share on other sites More sharing options...
mwiener2 Posted October 1, 2010 Share Posted October 1, 2010 the hose is near the downpipe My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Soda Popinski Posted October 1, 2010 Share Posted October 1, 2010 where does this hose originate from. does it connect to the drains in the back of the engine bay by the windshield? Link to comment Share on other sites More sharing options...
mwiener2 Posted October 1, 2010 Share Posted October 1, 2010 no, it connects to the bottom of your evaporator My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
RedDawg Posted October 1, 2010 Share Posted October 1, 2010 i need to do this as well, gf found a damp passenger footwell a few weeks ago. just need the time to do it. Link to comment Share on other sites More sharing options...
magdalenha Posted December 7, 2014 Share Posted December 7, 2014 i need to do this as well, gf found a damp passenger footwell a few weeks ago. just need the time to do it. Im having the same issue, how did you fix it??? Link to comment Share on other sites More sharing options...
