vespolis Posted July 12, 2007 Share Posted July 12, 2007 Here is the story...the left headlight was out on my lgt wagon so I replaced both headlights with new bulbs. They worked fine that day. The next day I noticed the little blue 'highbeam' light was on in my instrument panel. I went and looked at my headlights and now the left highbeam is on (left headlight is off) and the right headlight is on! What is going on? Link to comment Share on other sites More sharing options...
vespolis Posted July 14, 2007 Author Share Posted July 14, 2007 I looked at the fuse and it is not blown. I even tried to replace the bulb but the problem persists. I will be going to the dealership this week. Link to comment Share on other sites More sharing options...
Scooter Posted July 22, 2007 Share Posted July 22, 2007 I messed up replacing a headlight bulb and got the polarity switched up, and that bulb was very dim compared to other side. I took it out, rotated it 180degrees, and slapped it back in and it lit up full just like the other side. I'm not sure if this is what you are describing or not, but the bulbs are meant to be installed in one specific orientation. Seek first to understand, then to be understood. In other words: SEARCH before you post! Link to comment Share on other sites More sharing options...
derffred Posted July 22, 2007 Share Posted July 22, 2007 Sounds like you have a highbeam out, and a low beam out... double check your electrical connections... Link to comment Share on other sites More sharing options...
vespolis Posted July 23, 2007 Author Share Posted July 23, 2007 I took it to the dealer, they said the fuse was blown:confused: because a wire got crossed when I installed new the new lowbeam bulb. It works fine now, but I checked the fuse (#32 I think) and it was fine. Oh well...it just seems wierd. I guess a visual inspection of the fuse was where I went wrong, I should have put in a new one. Link to comment Share on other sites More sharing options...
