Carter Posted July 10, 2007 Share Posted July 10, 2007 When I had my Z an intake and UD pulley was Stage 1. When I had my S4 an ECU upgrade was an automatic jump to Stage 2. What would just an intake on the Legacy be??? How about intake and exhaust? Link to comment Share on other sites More sharing options...
BDII Posted July 10, 2007 Share Posted July 10, 2007 Jedimaster did. He also runs the SOA website. Just an intake is nothing stage 1 = tune stage 2 = tune + up pipe/down pipe (minimum) stage 3 = dyno tune/e tune, UP/DP, full exhaust and turbo upgrade Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
chenc544 Posted July 10, 2007 Share Posted July 10, 2007 Unlike the Z32, in which the intake system seem like an afterthought by Nissan, Subaru actually did a pretty good job with designing the stock intake. A CAI will not gain any power for the LGT and might actually give you some headaches. Link to comment Share on other sites More sharing options...
Carter Posted July 10, 2007 Author Share Posted July 10, 2007 I'm going to buy the SPT intake and heat shield along with a new exhaust. They claim on a WRX the gains are big with that combo. Who knows with the LGT. Link to comment Share on other sites More sharing options...
PhilT Posted July 10, 2007 Share Posted July 10, 2007 I'm going to buy the SPT intake and heat shield along with a new exhaust. They claim on a WRX the gains are big with that combo. Who knows with the LGT. Lot's of people know, it won't really gain you anything except a lighter wallet. Search the forum and you will find the reason why. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted July 10, 2007 Share Posted July 10, 2007 I'm going to buy the SPT intake and heat shield along with a new exhaust. They claim on a WRX the gains are big with that combo. Who knows with the LGT. don't bother with the SPT intake carter. Just get the exhaust. Link to comment Share on other sites More sharing options...
chenc544 Posted July 10, 2007 Share Posted July 10, 2007 I'm going to buy the SPT intake and heat shield along with a new exhaust. They claim on a WRX the gains are big with that combo. Who knows with the LGT. It's your money and your car... Do as you wish. Link to comment Share on other sites More sharing options...
Neurodancer Posted July 10, 2007 Share Posted July 10, 2007 I'm going to buy the SPT intake and heat shield along with a new exhaust. They claim on a WRX the gains are big with that combo. Who knows with the LGT. I downloaded a .pdf from Cobbforums that had extensive testing of the SPT intake. Unfortunately, I cannot find the link to send to you right now, but here are a couple snippets from it: <snip> Is the SPT or any aftermarket intake even necessary? The short answer is NO. We found that the stock LGT intake system is a thoroughly engineered system that does not restrict the vehicles performance at all, even up to a Stage2 level. The final portion of our testing helped us determine if an aftermarket intake is even necessary on a stock, Stage1, or Stage2 Legacy GT. We were able to determine this by measuring and recording the amount of vacuum generated between the stock intake housing and the turbo compressor inlet. These tests were performed at WOT in 3rd gear, which is a condition that should generate the most amount of vacuum in the turbo inlet tube. ... Please take into account that the size of the MAF housing on the stock Legacy GT is the largest one Subaru has ever used on a USDM turbo-charged vehicle, it is even bigger than the stock STi MAF housing. One last part we wanted to write about was our driving impressions with the SPT intake system. We found that the vehicle became more hesitant while running the SPT intake system; you could feel the ECM removing timing. The vehicle also felt slower (which our dyno tests showed as well) while driving with the SPT intake system. In conclusion, our test results demonstrated that one would have no reason to run any intake system other than the stock intake system on a 2005+ Legacy GT (up to a Stage2 level). We hope this information helps you make a better decision when choosing performance hardware for you Legacy GT. <snip> Hope this helps -- Cobb seemed to have a lot of data showing the intake was useless. But I believe they also weren't using a heatshield in the testing... Link to comment Share on other sites More sharing options...
Carter Posted July 10, 2007 Author Share Posted July 10, 2007 The stock intake plumbing to me on the LGT seems complicated. I was going to get the SPT heatshield in conjunction with the SPT intake. Also I can understand what they mean. On my 2001 S4 the stock intake was superior to any aftermarket intake due to the fact the the snorkel took air right from behind the grill. In the S4 Engine bay there is a lot of heat and little space and an aftermarket "CAI" would just be sucking in all the engine heat. Link to comment Share on other sites More sharing options...
BDII Posted July 10, 2007 Share Posted July 10, 2007 AHEM!!!! TDC tuned in 14-24 extra WHP with the SPT. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Carter Posted July 10, 2007 Author Share Posted July 10, 2007 AHEM!!!! TDC tuned in 14-24 extra WHP with the SPT. With or without heatshield? I'm sure some of these tests (as stated above) are without a heat shield. I would think it really would make all the difference. Link to comment Share on other sites More sharing options...
BDII Posted July 10, 2007 Share Posted July 10, 2007 I dont have one... I do feel alot of heat soak in the summer. That's nothing WI can't take care of. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
PhilT Posted July 10, 2007 Share Posted July 10, 2007 AHEM!!!! TDC tuned in 14-24 extra WHP with the SPT. Link to dyno please Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
KartRacerBoy Posted July 10, 2007 Share Posted July 10, 2007 Who is the guru of stages on the LGT? Somewhere in Nepal, there is a Buddist monk with a 2005 LGT 5MT (for craps sake, it's the mountains!) by the name of Bruce Willis who is slowly modding his car via the power of AVO. He is the source of all stage knowledge. You can quote me. Link to comment Share on other sites More sharing options...
chenc544 Posted July 10, 2007 Share Posted July 10, 2007 Link to dyno please http://legacygt.com/forums/showthread.php?t=49554 Not sure if this is what he means but here is the thread about the AEM intake. They got 13 whp over stock box and 10 whp over SPT with a tune, which would imply the SPT is only good for 3 whp... Keep in mind this is with stage 2+ hardware already. Stock + SPT intake, or any intake for that mater, would probably net you next to nothing especially without a tune. Link to comment Share on other sites More sharing options...
Carter Posted July 10, 2007 Author Share Posted July 10, 2007 You know, Im just looking for that BOV sound. Link to comment Share on other sites More sharing options...
PhilT Posted July 11, 2007 Share Posted July 11, 2007 http://legacygt.com/forums/showthread.php?t=49554 Not sure if this is what he means but here is the thread about the AEM intake. They got 13 whp over stock box and 10 whp over SPT with a tune, which would imply the SPT is only good for 3 whp... Keep in mind this is with stage 2+ hardware already. Stock + SPT intake, or any intake for that mater, would probably net you next to nothing especially without a tune. I know they had gains with the AEM, and to a lesser extent with the K&N, but never heard anything good about the SPT, thus the question. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
BDII Posted July 11, 2007 Share Posted July 11, 2007 he has it backwards, I think, IIRC Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
imstillatwork Posted July 11, 2007 Share Posted July 11, 2007 'Stages' are arbitrary and lack real meaning. They should only be used in the context of a specific manufacture. 'Stages' are different from vehicle to vehicle and manufacturer to manufacture. Stage 1 from company x on car a is NOT necessarily the same or even close to the same list of major parts / work as Stage 1 from company y on car b... Link to comment Share on other sites More sharing options...
