NSFW Posted July 2, 2007 Share Posted July 2, 2007 Pardon the alphabet soup. Does anyone make an off-the-shelf UP/DP for the Legacy with the external wastegate already built in? Thanks! Link to comment Share on other sites More sharing options...
mikeyan Posted July 2, 2007 Share Posted July 2, 2007 UP yes, i believe unorthodox racing has one that should work.... DP would need some modification SoCal Duck Hunters Club - Unit 52 Link to comment Share on other sites More sharing options...
NSFW Posted July 2, 2007 Author Share Posted July 2, 2007 It's an Impreza setup, I assume? Link to comment Share on other sites More sharing options...
AWDxBOOST Posted July 2, 2007 Share Posted July 2, 2007 you just need the uppipe to run ewg....you dont have to plump it back into the downpipe if you dont want to ultimate racing should have an uppipe that will probably work Link to comment Share on other sites More sharing options...
mikeyan Posted July 2, 2007 Share Posted July 2, 2007 yeah, wrx/sti fitment. I believe some, iirc the Helix for example, don't work with the legacy. I think Ian@ Harman motive runs a UR uppipe. Mike SoCal Duck Hunters Club - Unit 52 Link to comment Share on other sites More sharing options...
AWDxBOOST Posted July 2, 2007 Share Posted July 2, 2007 i thought some dude got the helix v3 to work? Link to comment Share on other sites More sharing options...
mikeyan Posted July 2, 2007 Share Posted July 2, 2007 wasn't it hitting something or other, or aiming right at the cv boot? SoCal Duck Hunters Club - Unit 52 Link to comment Share on other sites More sharing options...
NSFW Posted July 2, 2007 Author Share Posted July 2, 2007 Actually, *I* do need it plumbed back into the DP. I don't want the extra noise. IIRC the wxr/sti DP is about 4 inches too short. Somebody was prototyping a bolt-on extension that would make them Legacy-compatible, but that never got into production as far as I know. Link to comment Share on other sites More sharing options...
AWDxBOOST Posted July 2, 2007 Share Posted July 2, 2007 well if youre going to plump it back in then your gonna have to have some fabrication done on the dp i would imagine anyways. pretty much any place that can cut and weld exhausts can make that extension for you Link to comment Share on other sites More sharing options...
mikeyan Posted July 2, 2007 Share Posted July 2, 2007 yeah, agreed, any shop should be able to help you out with that. I just did a quick search, the helix did have some issues, but the UR one worked great. But if you're gonna plumb it into the DP, either should work from what the pics show. Mike SoCal Duck Hunters Club - Unit 52 Link to comment Share on other sites More sharing options...
PartyWagon Posted July 11, 2007 Share Posted July 11, 2007 Is this what you're looking for? http://www.crucialracing.com/products/lgt_downpipe.php Make it idiot-proof and someone will make a better idiot. .../PartyWagon/... Link to comment Share on other sites More sharing options...
NSFW Posted July 11, 2007 Author Share Posted July 11, 2007 Nope... that's a downpipe with a divorced wastegate tube. It works with an internal wastegate, i.e. a wastegate that is built into the turbocharger itself. An external wastegate sits between the up-pipe and down-pipe. Picture the narrower tube on that down-pipe connecting to the up-pipe (via wastegate) rather than connecting to the turbocharger's exhaust outlet. Click here for a picture of an EWG setup, from a Perrin kit for the STI: http://www.perrinperformance.com/shared/images/products/202/360_large.jpg Link to comment Share on other sites More sharing options...
PartyWagon Posted July 12, 2007 Share Posted July 12, 2007 Nope... that's a downpipe with a divorced wastegate tube. It works with an internal wastegate, i.e. a wastegate that is built into the turbocharger itself. An external wastegate sits between the up-pipe and down-pipe. Picture the narrower tube on that down-pipe connecting to the up-pipe (via wastegate) rather than connecting to the turbocharger's exhaust outlet. Click here for a picture of an EWG setup, from a Perrin kit for the STI: http://www.perrinperformance.com/shared/images/products/202/360_large.jpg Wow, that's a pretty piece of hardware. I totally need to spend some time with an experienced modder and get skooled on all this stuff... Make it idiot-proof and someone will make a better idiot. .../PartyWagon/... Link to comment Share on other sites More sharing options...
