C_randyjones Posted June 26, 2007 Share Posted June 26, 2007 silly question: Do I need to use permatex or similar gasget matterial when installing or will the new gaskets be sufficient? Link to comment Share on other sites More sharing options...
qikslvr Posted June 27, 2007 Share Posted June 27, 2007 If you are just putting new mufflers on and leaving everything else stock; you should be able to just use new gaskets. The only place I used the Hi-Temp Permatex is at the DownPipe->Mid-Pipe(Catback) union. Let's kick this pig! Link to comment Share on other sites More sharing options...
C_randyjones Posted June 27, 2007 Author Share Posted June 27, 2007 Thanks for the reply. I got the mufflers on and they sound great from the outside but do drone a little on the highway...as expected I guess after reading throught multiple threads on the topic. Fitment and appearance is great. Link to comment Share on other sites More sharing options...
qikslvr Posted June 27, 2007 Share Posted June 27, 2007 Ya, I went from stock to UP/DP one week then put on an SPT CBE with SPT mufflers the next week and it got loud quick! There's just a little drone going down the highway, but I think I have a fix. I'm either going to try spraying some undercoating right above the mufflers or stick some black sheets of dyna-mat (or whatever you call that stuff they use in the trunk to keep subwoofer noise in) up there. It's weird, you only hear it right at the rear corners of the car with the windows up. This is what makes me think we can kill the sound. It still rang through my trunk with a full load in there. Let's kick this pig! Link to comment Share on other sites More sharing options...
