meanrick69 Posted November 17, 2004 Share Posted November 17, 2004 Just picked up piaa starwhite bulbs for the heads, brights, and road lights. How do you get to the road lights and headlights? The highbeams seem easy to get to? Link to comment Share on other sites More sharing options...
gtguy Posted November 17, 2004 Share Posted November 17, 2004 It's quite thoroughly described in the owner's manual. It's an easy change. Kevin Link to comment Share on other sites More sharing options...
meanrick69 Posted November 17, 2004 Author Share Posted November 17, 2004 [font=Arial][size=1]The book says how to do the low & high beams, but the road lights should be done at the dealer. Is it that hard? What do you have to move to get to the low beams? Seems kinda of a pain to get to them.[/size][/font] Link to comment Share on other sites More sharing options...
gtguy Posted November 17, 2004 Share Posted November 17, 2004 You don't have to move anything, but it would help if your hands are small. :lol: Kevin Link to comment Share on other sites More sharing options...
meanrick69 Posted November 17, 2004 Author Share Posted November 17, 2004 [font=Arial][size=1]I just took the plastic off around the road light and i dond see anyway to change it from the front, (that would be to easy!) I guess all that plastic has to come off on the bottem to get to the bulb. Seems like a pain just to change a bulb![/size][/font] Link to comment Share on other sites More sharing options...
rc0032 Posted November 17, 2004 Share Posted November 17, 2004 [font='Times New Roman']If I remember right you have to drop the bumper to change the fog lights. [/font] Link to comment Share on other sites More sharing options...
meanrick69 Posted November 17, 2004 Author Share Posted November 17, 2004 I hope your kidding! could they make it any harder? the hell with it!!!:mad: Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted November 17, 2004 Share Posted November 17, 2004 It's really easy to remove the front bumper- about 13 plastic clips hold it on. I'm getting really good at it by now :lol: I put silver bulbs in my signals and there was no way my hand would fit in to twist the bulbs out- I took the bumper off and pulled the headlights- start to finish is about 25 minutes. I also had it off the other day to reattach a wire that had fallen off after putting new horns in. It's really very simple- use a plastic drop cloth to protect the bumper cover once its' off. Link to comment Share on other sites More sharing options...
rc0032 Posted November 17, 2004 Share Posted November 17, 2004 I was wrong sorry, look at post #9 [url="http://www.legacygt.com/forums/showthread.php?t=2238&highlight=fog+lights"]http://www.legacygt.com/forums/showthread.php?t=2238&highlight=fog+lights[/url] Link to comment Share on other sites More sharing options...
meanrick69 Posted November 17, 2004 Author Share Posted November 17, 2004 Thanks i'll give it a shot. Link to comment Share on other sites More sharing options...
skubdu Posted November 17, 2004 Share Posted November 17, 2004 To replace the foglight bulbs you have to go under the car directly underneath the foglights. There will be 3 or 4 clips you have to take out and a 10mm bolt. Once you have the clips and bolt out pull the cover down and towards the tire. You will be able to see the foglights from here. there will be a black plastic dust cover on the back part of the lights which you have to twist counterclockwise to remove. Once you get the dust cover off the bulb is exposed. If you want to replace the park light/turn signal bulb this is the best time to do it just look straight up from where the cover is and you will see the bulb harness. The horn if you want to replace them are above the passenger side foglights. Hope this helps. Link to comment Share on other sites More sharing options...
meanrick69 Posted November 17, 2004 Author Share Posted November 17, 2004 Yep i pulled the plastic down and it got don fast and easy. thanks for the help. Link to comment Share on other sites More sharing options...
