BlackHole Posted June 5, 2007 Share Posted June 5, 2007 n00b question - why don't coilovers for the LGT have rear camber plates since the factory decided not to make camber adjustable? Yes it would add to cost, but adjustable lateral links aren't exactly cheap either. Kyle "BlackHole" Kyle "BlackHole" Link to comment Share on other sites More sharing options...
RobY Posted June 5, 2007 Share Posted June 5, 2007 You could put camber plates in the rear but they wont do anything.... The rear suspension is not a strut design. The camber or any part of the suspension localization other than the vertical localization is not effected by the position of the shock. The suspension is completely localized by its control arms. You could mount the coilover horizontally and the camber would remain the same Link to comment Share on other sites More sharing options...
whitetiger Posted June 5, 2007 Share Posted June 5, 2007 If you want to be able to adjust rear camber, get these http://www.perrinperformance.com/products/show/320/Rear-Control-Arms-Lateral-Links?category=8&model=10 Link to comment Share on other sites More sharing options...
NewScooby Posted June 5, 2007 Share Posted June 5, 2007 My rear camber was out of wack from the driver to passenger side after lowering. I watched the alignment shop even it out by adjusting the assentric bolts (sp?). I have read on here several times that the camber is not adjustable on the rear of legacy.....I'm no suspension expert, but I watched them adjust mine. They took it from -1.4 to -.6, I think Link to comment Share on other sites More sharing options...
whitetiger Posted June 5, 2007 Share Posted June 5, 2007 ^those bolt only adjust rear toe. rear roe also affect rear camber somewhat but there is no adjustment for rear camber only, unles you buy those perrin rear arms. Link to comment Share on other sites More sharing options...
RobY Posted June 5, 2007 Share Posted June 5, 2007 the eccentric bolts are for toe primarily. Link to comment Share on other sites More sharing options...
BlackHole Posted June 5, 2007 Author Share Posted June 5, 2007 The camber or any part of the suspension localization other than the vertical localization is not effected by the position of the shock. Duh, what was I thinking?! Never mind... Kyle "BlackHole" Kyle "BlackHole" Link to comment Share on other sites More sharing options...
Gmachine Posted June 5, 2007 Share Posted June 5, 2007 What you need is one of these "Adjustablelaterallinkcambermathingies"......... ....................................Perrin rear links. Link to comment Share on other sites More sharing options...
