feardaram Posted May 31, 2007 Share Posted May 31, 2007 so i picked up the mothers claybar kit from walmart (maybe thats my problem lol) after checking ocds page (great info btw). i have a white legacy and have quite a few of those orange dots on my car that will not come off with a standard wash, and was hoping claying would help. i washed the car, then busted out the clay. the directions with the clay said to not push hard on the clay. without pushing it seemed like the clay really wasnt doing anything. if i pushed hard on the orange spots some of them would come out, but none would come out if i didnt apply a bunch of pressure. i did the entire care with light pressure and it didnt notice a difference in the orange dots still covering my read bumper and doors. was i doing something wrong, using an inferior product, or just hoping it would take these dots out and it isnt intended to do that? thanks! Link to comment Share on other sites More sharing options...
PhilT Posted May 31, 2007 Share Posted May 31, 2007 Are you using the mothers lubricant when you clay ? I had the same problem with my white LGT, and it worked perfectly. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
iyalla Posted May 31, 2007 Share Posted May 31, 2007 For red spots you have to use some pressure, lots of rubbing with lots of lubricant (lol that sounds bad I have to get my mind out of the gutter ). Remember these over the counter clays are mild so you need a little more elbow grease to get them to remove contaminants like rust spots. When I have a car like this to do it hurts a little afterwards. BE CAREFUL! Sometimes when you rub too hard you could drop the clay or fling it by mistake into the bushes . Link to comment Share on other sites More sharing options...
pillboy Posted May 31, 2007 Share Posted May 31, 2007 For red spots you have to use some pressure, lots of rubbing with lots of lubricant (lol that sounds bad I have to get my mind out of the gutter ). Remember these over the counter clays are mild so you need a little more elbow grease to get them to remove contaminants like rust spots. When I have a car like this to do it hurts a little afterwards. BE CAREFUL! Sometimes when you rub too hard you could drop the clay or fling it by mistake into the bushes . Attack your Wii-mote wrist strap to it. It is still ugly. Link to comment Share on other sites More sharing options...
Andyjo Posted May 31, 2007 Share Posted May 31, 2007 Attack your Wii-mote wrist strap to it. make sure you get the updated one, because the originals were breaking when people threw the remotes at the tv Link to comment Share on other sites More sharing options...
Brady Posted May 31, 2007 Share Posted May 31, 2007 You can try stopping at Autozone (or probably most any other car-centric store) and pick up the ClayMagic Claybar. That's a good bar, it's cheap, and readily available. You might also find that the spots won't entirely go away because the rust will have stained the clearcoat. Remember that your clearcoat and paint are porous. It may be necessary to use a chemical paint cleaner (like Klasse AIO) to clean the staining, and it may still be necessary to machine polish the paint to get all the red spots out. The claybar only removes the metal which is the point of oxidation (rust), so if the rust is only on the piece of metal, the red spot comes out. If the rust has stained the paint/clearcoat, removing the metal with the claybar will only prevent further staining. Link to comment Share on other sites More sharing options...
OCDetails Posted May 31, 2007 Share Posted May 31, 2007 Remember that the orange dots are just indications of damage, but clay isn't supposed to remove the dots themselves. It is just supposed to remove the contamination. The orange dots are the rust stains on the paint and are best removed with a paint cleaner. As long as the surface is smooth, then don't worry about the dots. You'll get those with a polish or paint cleaner later. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
feardaram Posted June 9, 2007 Author Share Posted June 9, 2007 thanks for the responses, i completely forgot i posted this. could you guys give a little more info on paint cleaner? is that just the regular car wash stuff? something that would require a buffer? thanks! Link to comment Share on other sites More sharing options...
OCDetails Posted June 9, 2007 Share Posted June 9, 2007 Don't worry about it. You have a car that is only a year old. I seriously doubt you need a paint cleaner. It doesn't come in a car wash though. It would be a polish type product that would best be applied by machine. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
kenchan Posted June 11, 2007 Share Posted June 11, 2007 those mother's clays are kinda firm. they do fly out of my hands some times. i started using Prima's clay www.detailersparadise.com and they are softer and not so soft like Griot's clay. ive yet to drop it. this is moderate soft so will not haze your finish, but wax does come of a little. griot's clay wax stays as they are super soft. i use light pressure with clay. no issues with hazing. Link to comment Share on other sites More sharing options...
