Alpinestars96 Posted May 30, 2007 Share Posted May 30, 2007 Does anyone know of any cheap priced but lit up for the night time? Online? Thanks Link to comment Share on other sites More sharing options...
CreoSTi Posted May 31, 2007 Share Posted May 31, 2007 http://www.j-spectuning.com/product_info.php/products_id/126 -Mike- Link to comment Share on other sites More sharing options...
Alpinestars96 Posted May 31, 2007 Author Share Posted May 31, 2007 Any pics of that setup on a LGT? Link to comment Share on other sites More sharing options...
Spec B Posted May 31, 2007 Share Posted May 31, 2007 http://www.legacygt.com/forums/showthread.php?t=57417 Link to comment Share on other sites More sharing options...
CreoSTi Posted June 1, 2007 Share Posted June 1, 2007 Any pics of that setup on a LGT? http://www.mcnproductions.com/lgt/interior/omori1.jpg -Mike- Link to comment Share on other sites More sharing options...
jagcars26 Posted June 1, 2007 Share Posted June 1, 2007 <<identical setup,,Mike and I have good taste;) Link to comment Share on other sites More sharing options...
Abandonhope16 Posted June 1, 2007 Share Posted June 1, 2007 They don't get much cheaper than Prosport. I have one and really like it. Link to comment Share on other sites More sharing options...
CreoSTi Posted June 1, 2007 Share Posted June 1, 2007 <<identical setup,,Mike and I have good taste;) Yes we do. -Mike- Link to comment Share on other sites More sharing options...
Noktrnal_Legacy Posted June 2, 2007 Share Posted June 2, 2007 http://www.mcnproductions.com/lgt/interior/omori1.jpg -Mike- Your gauge looks white, not red like the one in the picture from the link provided. Did you just change the bulb or something? Looks very good/clean with the LGT gauges. I want that gauge set-up.. Link to comment Share on other sites More sharing options...
fatbastard Posted June 2, 2007 Share Posted June 2, 2007 Not sure but often they have two colors and it depends on which one you wire power to. Link to comment Share on other sites More sharing options...
CreoSTi Posted June 2, 2007 Share Posted June 2, 2007 Your gauge looks white, not red like the one in the picture from the link provided. Did you just change the bulb or something? The full color gauge has a "color box" with dials for red, green, and blue. So, you can adjust the background illumination to different colors. I have the same gauge/pod in my FXT (adjusted to match the green dash lighting); http://www.mcnproductions.com/fxt/omoricolor.jpg -Mike- Link to comment Share on other sites More sharing options...
Jim_KT Posted June 6, 2007 Share Posted June 6, 2007 <<identical setup,,Mike and I have good taste;) I must have better taste because mine is mounted on the right side of the steering column. Link to comment Share on other sites More sharing options...
vitarelli Posted June 7, 2007 Share Posted June 7, 2007 Mike, Where is that color box mounted in your setup? Link to comment Share on other sites More sharing options...
CreoSTi Posted June 7, 2007 Share Posted June 7, 2007 Mike, Where is that color box mounted in your setup? It's mounted on the lower dash fuse panel access cover. -Mike- Link to comment Share on other sites More sharing options...
