JonR Posted May 27, 2007 Share Posted May 27, 2007 I am considering buying some LGT wheels for my OBXT for winter tires. I know the offsets are different, but does that make a difference in fit? I have searched and only found this thread which doesn't really specify: http://legacygt.com/forums/showthread.php?t=4814 So, what is the consensus? Thanks! Link to comment Share on other sites More sharing options...
JonR Posted June 6, 2007 Author Share Posted June 6, 2007 Bump for more info Link to comment Share on other sites More sharing options...
JonR Posted August 16, 2007 Author Share Posted August 16, 2007 Still wondering...anyone? Link to comment Share on other sites More sharing options...
Xenonk Posted August 16, 2007 Share Posted August 16, 2007 as long as your tire size matches to your OBXT it's fine.. read the FAQ and you'll be ok. the rim itself will fit fine on your car (just treat it as upsizing or buying any other aftermarket 17" rim for you OBXT). just make sure you buy the appropriate tire size (your OBXT I think runs on anything from a 25.5" to 27.0" diameter tall tire). Post #16 in my tire FAQ has your answer for tire sizes.. later, I will copy that post and put in the 1st post for easy look up and reading. Keefe Link to comment Share on other sites More sharing options...
