Mo_GT Posted May 26, 2007 Share Posted May 26, 2007 Hi All, Does anyone have any pics of the clock relocation panel /bezel just as a part? I'd like to see what is supplied withthis part and what it looks like. I'm not going to relocate my clock but want to see if i can use the panel to install something else in the ashtray slot. Here's a pic of what it is: http://www.japanparts.com/images/ImageFromDB.php?base=1&no=2473 Thanks, Mo Link to comment Share on other sites More sharing options...
Googalash Posted May 28, 2007 Share Posted May 28, 2007 Hey Mo_GT Sadly I do not have a pic of just the part. What I can tell you is that it is just a plastic bezel that the clock unit snaps into and the bezel piece snaps into where the ashtray goes. Its pretty much a 1 piece part. Here is a pic of it installed in my car if that helps at all. http://i8.photobucket.com/albums/a41/googalash/Car/DSC00988.jpg Link to comment Share on other sites More sharing options...
Mo_GT Posted May 29, 2007 Author Share Posted May 29, 2007 Thanks Googalash, i was hoping it would be a one piece part. Also, what did it cost you? Sebberry, my car is a RHD Bye, Mo Link to comment Share on other sites More sharing options...
ATB Posted May 29, 2007 Share Posted May 29, 2007 What modifications (if any) did you need to do to make it fit? Hey Mo_GT Sadly I do not have a pic of just the part. What I can tell you is that it is just a plastic bezel that the clock unit snaps into and the bezel piece snaps into where the ashtray goes. Its pretty much a 1 piece part. Here is a pic of it installed in my car if that helps at all. http://i8.photobucket.com/albums/a41/googalash/Car/DSC00988.jpg Link to comment Share on other sites More sharing options...
Spec B Posted May 29, 2007 Share Posted May 29, 2007 Does this help? http://www.legacygt.com/forums/showthread.php?t=24969&highlight=Relocate+clock or http://legacygt.com/forums/showthread.php?t=23059&highlight=usdm+clock Link to comment Share on other sites More sharing options...
Mo_GT Posted May 30, 2007 Author Share Posted May 30, 2007 Thanks Spec B, that gives me some ideas too. Link to comment Share on other sites More sharing options...
Legasee Posted May 30, 2007 Share Posted May 30, 2007 Spec B-- great job and thanks for sharing! In Taiwan now... Link to comment Share on other sites More sharing options...
Googalash Posted May 30, 2007 Share Posted May 30, 2007 Actaully I did not have to mod the kit at all. The kit works in a LHD car with no problem. One thing to note though is that the kit coems with an extension cable. DO NOT use it. The extension while having the correct plugs on both ends is missing 2 wires for the passanger airbag weight sensor system. So the you get a CEL because the car will think that the passanger airbag sensor is not hooked up/working. Link to comment Share on other sites More sharing options...
