LordJim Posted May 19, 2007 Share Posted May 19, 2007 So, today while goofing around in a parking lot (empty) I had to make a quick brake and probably dumped my drivers side front tire into a pot hole. Since that time the car starts to shimmy and shake at speeds approaching 45 or 50. It's going to the dealer in a few hours, but any idea what I might have done? What I might be in for? Thanks, Jim Link to comment Share on other sites More sharing options...
mattg Posted May 19, 2007 Share Posted May 19, 2007 it's either a bent rim or a separated tire, or both. Link to comment Share on other sites More sharing options...
LordJim Posted May 19, 2007 Author Share Posted May 19, 2007 I considered that, but . . . (and I was on my way to edit the original post) when looking at the car from the front it appears that the entire wheel assembly is cocked in a bit at the bottom. Meaning - that the bottom of the tire/wheel seems cocked in a bit into the wheel well area. Does that make sense? Tire seems to be firmly attached to the rim. - Jim Link to comment Share on other sites More sharing options...
mattg Posted May 19, 2007 Share Posted May 19, 2007 do you mean the tire is moved back in the wheel well, or the bottom of the wheel is moved in towards the center of the car, aka + camber? Link to comment Share on other sites More sharing options...
LordJim Posted May 19, 2007 Author Share Posted May 19, 2007 Camber. Thanks for the correct term. - Jim Link to comment Share on other sites More sharing options...
beatadrum Posted May 19, 2007 Share Posted May 19, 2007 i had the same issue except the top was cocked in, not the bottom. Turned out i broke the strut and alignment was off. Link to comment Share on other sites More sharing options...
pillboy Posted May 19, 2007 Share Posted May 19, 2007 Stay out of Wal-Mart parking lots. It is still ugly. Link to comment Share on other sites More sharing options...
Bryan l Posted May 20, 2007 Share Posted May 20, 2007 could have done allot of things. From breaking control arms, ball joints, tie rods ect ect. I have seen this type of thing cost in the range of 6k due to damage to CV joints, bearings, everything listed above, rims ect. I hope its not MAJOR. but dont be floored if it comes in well over 1k. good luck Link to comment Share on other sites More sharing options...
LordJim Posted May 20, 2007 Author Share Posted May 20, 2007 Oh. That would suck. D'oh! Link to comment Share on other sites More sharing options...
bms231 Posted May 20, 2007 Share Posted May 20, 2007 probably knocked out the alignment or bent a camber bolt if u hit that hard. Link to comment Share on other sites More sharing options...
hogmeat Posted May 20, 2007 Share Posted May 20, 2007 anything from minor to major! watch it! I'm pleasantly surprised... It was most certainly worth the couple bucks and 10 mins of my time. CLICK HERE FOR THE HOGZAUST Link to comment Share on other sites More sharing options...
LordJim Posted May 20, 2007 Author Share Posted May 20, 2007 You're right about watching it. You'd think that at 36 that I'd know better. - Jim Link to comment Share on other sites More sharing options...
Brady Posted May 20, 2007 Share Posted May 20, 2007 You're right about watching it. You'd think that at 36 that I'd know better. - Jim I have a feeling that if you love to push cars, you'll never really know better. Sure, I've become wiser over time ... but the urges never seem to go away. Link to comment Share on other sites More sharing options...
ArcTec34 Posted May 20, 2007 Share Posted May 20, 2007 my brother did a similar thing with his trailblazer but it was into a curb in the snow :-p. it didnt cost much to get fixed because there were huge tolerances for connecting the suspension parts so they could use all the same parts, even though some were a little bent. but yeah i dunno about subarus Link to comment Share on other sites More sharing options...
Googalash Posted May 20, 2007 Share Posted May 20, 2007 Hmmm I hope its not major. Personally I hit a patch of black ice on a narrow road and put one of my wheels in a ditch in the process of regaining control. Anyway it hit hard enogh to bend my lower control arm and broke an end link. So yeah hopefully yous is not near as bad. Link to comment Share on other sites More sharing options...
darren94 Posted May 20, 2007 Share Posted May 20, 2007 i had the same issue except the top was cocked in, not the bottom. Turned out i broke the strut and alignment was off. exact same thing happened to me. 1000 bucks later, the prob was fixed(new volk wheel, tire, mount and balance and alignment) Link to comment Share on other sites More sharing options...
