sportwagon Posted May 18, 2007 Share Posted May 18, 2007 I have been waiting for a long time to get my suspension pieces installed... I had them since last fall, but figured it would be better to install them after the harsh New England Winter ( )... I have JDM GT rev A Bilstiens and I also ordered upper strut mounts, seats, dust covers, etc. Everything that is needed for the strut/spring combo without using any of the stock pieces. I just realized I only have two dust boots! Should there be four? Do the rear shocks use dust boots? If the do... are they the same size as the fronts? Thanks for the help! Link to comment Share on other sites More sharing options...
hifiandmtb Posted May 18, 2007 Share Posted May 18, 2007 http://photos.all.id.au/ALBUMS/SJ_Whiteline_Control/IMG_6068.sized.jpg http://photos.all.id.au/ALBUMS/SJ_Whiteline_Control/IMG_6067.sized.jpg I think you should be ok using the OEM dust boots on the Bilstein rear dampers. Link to comment Share on other sites More sharing options...
sportwagon Posted May 18, 2007 Author Share Posted May 18, 2007 they look like they are the same size for both front and back! Link to comment Share on other sites More sharing options...
whitetiger Posted May 18, 2007 Share Posted May 18, 2007 I dont supose stock dust boots will fit on the new struts? Link to comment Share on other sites More sharing options...
sportwagon Posted May 18, 2007 Author Share Posted May 18, 2007 probably will, but I want to have a complete set of bilstein/pinks and stock struts/springs... so I can swap out completely if need be! Link to comment Share on other sites More sharing options...
SC GT Posted May 18, 2007 Share Posted May 18, 2007 The part number for stock rear dustboots is 20372AE00A. They are around $5 each, and they are a different part number than the front dust boots. Link to comment Share on other sites More sharing options...
sportwagon Posted May 19, 2007 Author Share Posted May 19, 2007 There are spec B rear dust boots available... wouldn't they be more applicable than the stock ones? Link to comment Share on other sites More sharing options...
Guest Posted May 20, 2007 Share Posted May 20, 2007 Front boots for Bilsteins are different. Check my faq for part #. Rears are the same. Link to comment Share on other sites More sharing options...
