fatbastard Posted May 17, 2007 Share Posted May 17, 2007 On the way home tonight I thought the radio sounded strange then noticed the volume was changing. I looked over and I could see it jumping between 7 and 8 then I adjusted the volume manually and it went away. I did a search and found a thread about this froma long time ago but not much else. Some suggested that it was just going to get worse and the HVAC/radio needed to be replaced. Has anyone had experience with this? I ask because I have 29969 miles on the car and hte warranty will expire tomorrow so I am wondering if I should go in and mention it but I don't even know if they would do anything. Thoughts? Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted May 17, 2007 Share Posted May 17, 2007 3yr/36k not 30k. Link to comment Share on other sites More sharing options...
fatbastard Posted May 17, 2007 Author Share Posted May 17, 2007 Doh....I am an idiot....but at least I have some time. Anyone have experience with this problem? Link to comment Share on other sites More sharing options...
CSTMIZR Posted May 17, 2007 Share Posted May 17, 2007 This is a common and recognized (by SOA) problem, take it the dealer and they should replace the unit for you under warranty. Here's a link with a short explanation: http://legacygt.com/forums/showthread.php?t=61008&highlight=volume+control Hope it works out for you too. Link to comment Share on other sites More sharing options...
fuzzydd Posted May 18, 2007 Share Posted May 18, 2007 Is there any sort of TSB for this, I've only encountered the problem once or twice in my 6 months of ownership, but I don't want to waste my time going to the dealer and getting turned away cause they can't reproduce it.. Link to comment Share on other sites More sharing options...
fatbastard Posted May 18, 2007 Author Share Posted May 18, 2007 Is there any sort of TSB for this, I've only encountered the problem once or twice in my 6 months of ownership, but I don't want to waste my time going to the dealer and getting turned away cause they can't reproduce it.. That is kind of where I am at too. If it is only going to get worse I'll go have tehm look but expect to hear they can't/won't do anything about it, plus add in the jazzy mod I have means I'll have to pull the radio, remove all that stuff and then reinstall just hoping they'll replace it. Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted May 19, 2007 Share Posted May 19, 2007 Jazzy mod? Link to comment Share on other sites More sharing options...
fatbastard Posted May 19, 2007 Author Share Posted May 19, 2007 Jazzy mod? The line in adaptor made by jazzymt : http://www.legacygt.com/forums/showthread.php?t=18504 Link to comment Share on other sites More sharing options...
gianspi Posted May 22, 2007 Share Posted May 22, 2007 ...but I don't want to waste my time going to the dealer and getting turned away cause they can't reproduce it.. I've been to the dealer 4 times because of this. Each time I get "Cannot reproduce error". It's in the shop again. If they tell me this again I'm going to strangle someone. enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
ongdo Posted May 23, 2007 Share Posted May 23, 2007 Can some one give me more information about this problem? Wheather conditions, Road conditions, Driving area (industrial or residential). It happen when driving or parking. vehicle infomation when volume change by itself: Air condition on or off. heat on or off. Radio or CD Playing. how many times has this issue occurred? When it change does it come back or you have to adjust by manual? Thanks, Link to comment Share on other sites More sharing options...
fatbastard Posted May 24, 2007 Author Share Posted May 24, 2007 When mine happened it was a clear day, road was fairly smooth county road going through a residential area, HVAC was on and I was playing a CD. Once it started randomly changing the volume I had to manual change it to stop it. Link to comment Share on other sites More sharing options...
fuzzydd Posted May 24, 2007 Share Posted May 24, 2007 Just got off work, started up the car and it started changing intermittently (commercial area), was clear but cold day, A/C was on auto, playing a CD Changed the volume and it went away.. Link to comment Share on other sites More sharing options...
