legacy2.5i Posted May 8, 2007 Share Posted May 8, 2007 When I go to put my S Tech springs on, is there any kind of camber kit or anything of that nature that I should also purchase when doing the job? Thanks for the help! Link to comment Share on other sites More sharing options...
Efinirx8 Posted May 8, 2007 Share Posted May 8, 2007 To my knowledge you shouldn't have to purchase a camber kit just make sure to get your car aligned after the springs have settled. Link to comment Share on other sites More sharing options...
Xenonk Posted May 9, 2007 Share Posted May 9, 2007 the front end has OEM eccentric bolts.. you can use those to dial in the correct amount of camber that you need.. i think they are able to correct -/+1 degree at stock height. But it's best to get an alignment done anyways. Keefe Link to comment Share on other sites More sharing options...
legacy2.5i Posted May 9, 2007 Author Share Posted May 9, 2007 Awesome! Thanks for the help. Also, while I am doing all of that, would anyone recommend getting any bushings for anything or you think I will be good with OEM? Link to comment Share on other sites More sharing options...
