importtund Posted May 3, 2007 Share Posted May 3, 2007 Ok, I feel stupid again, as I did when I asked the difference between the BH/BG-BD/ and so forth, but..... What makes a legacy a legacy-outback? Is my 99' legacy LTD ah legacy-outback or just ah legacy? Link to comment Share on other sites More sharing options...
Bdubs Posted May 3, 2007 Share Posted May 3, 2007 Just a legacy. Early model years featured large fog lights, and a bigger suspension. Other than that, everything else is the same. Newer models feature an H6 engine which isn't available in a plain ole Legacy. There is a wagon and a sedan(SUS-sport utility sedan). It started as just a trim package in 95, but then became its own model line in 96. There is also an Impreza Wagon "Outback", but thats an entirely different thing. Link to comment Share on other sites More sharing options...
importtund Posted May 3, 2007 Author Share Posted May 3, 2007 Just a legacy. Early model years featured large fog lights, and a bigger suspension. Other than that, everything else is the same. Newer models feature an H6 engine which isn't available in a plain ole Legacy. There is a wagon and a sedan(SUS-sport utility sedan). It started as just a trim package in 95, but then became its own model line in 96. There is also an Impreza Wagon "Outback", but thats an entirely different thing. ok well the reason I ask is because I'm trying to replace my rack and pinion and it's asking if it's ah legacy or legacy-outback first timme I've seen this?!?! http://www.sl-i.net/FORUM/images/smiles/icon_rolleyes.gif http://www.partstrain.com/submodel/Vehicles/1999~SUBARU~LEGACY~4~2-dot-5~LEGACY.html and then when I select legacy, it goes to this... http://www2.partstrain.com/products/Engine/Steering/Rack_and_Pinion_Assembly/1999~SUBARU~LEGACY~4~2-dot-5~LEG-4WD2.5-001.html it says it will fit both there? WTF? and on another site you select legacy al the way through the choices and it gives you results for "outback chassis" http://www.autopartswarehouse.com/bizshop/yymmp/subaru/legacy/rack_and_pinion_assembly/1999/1999.html?apwcid=P1135867996W43b3f85c7ab9e&apwkwd=99+Subaru+Legacy+Rack+and+Pinion+Assembly http://www2.partstrain.com/partlisting/full/subaru/legacy/rack_and_pinion_assembly/1999/1999.html?ptc=S1171391678W45d204bec356b&ptk=1999+Subaru+Legacy+Rack+and+Pinion+Assembly+-+Subaru+99+Rack+and+Pinion+Assembly I'm so confused, I don't wanna pay 250 for sumthin that's not going to work and subaru wants an ass load of cash to order this thing... Link to comment Share on other sites More sharing options...
Bdubs Posted May 3, 2007 Share Posted May 3, 2007 They're all the same part #, so they both must fit outback and legacy's. Link to comment Share on other sites More sharing options...
importtund Posted May 3, 2007 Author Share Posted May 3, 2007 They're all the same part #, so they both must fit outback and legacy's. See that's what I though, but the people at subaru are telling me their slightly different, I think their just trying to get the sell... I guess I'll order it and find out?! Thanks for the help... (This forum rocks)! Link to comment Share on other sites More sharing options...
Bdubs Posted May 4, 2007 Share Posted May 4, 2007 I'm worried they may be different, because the suspensions are different between the two cars. Your best bet would be to get the part number from the stealership, then go to subarugenuineparts.com or subarupartsforyou.com, and you can enter the part number right on the site. Even if you purchase the incorrect item, as long as you provide your VIN, they will let you know you bought the wrong thing, and correct it. Very nice and convienient. I'm an OEM nut, something like that I would only use a genuine subaru part. Link to comment Share on other sites More sharing options...
importtund Posted May 4, 2007 Author Share Posted May 4, 2007 https://www.subarugenuineparts.com/oe_parts_cat.html WOW! Link to comment Share on other sites More sharing options...
