mmanus88 Posted November 8, 2004 Share Posted November 8, 2004 i am in search of a module that has the same design as the kenwood ready2go unit ("flat book design" since that type would fit perfect in the ashtray section. all of the other designed are "vertical." i check sirius's sight and the ready2go is the only such unit that is listed there, does sirius have all modules avalable for its service or are there any others not on their site? Link to comment Share on other sites More sharing options...
Screaming2.5 Posted November 9, 2004 Share Posted November 9, 2004 [font=Times New Roman][size=3]I don't know about "other" available options for horizontal design HU, but the Kenwood fits perfect in the hole where the ashtray originally went. The ashtray comes out really easy and can be replaced easily if you want to take the HU out...[/size][/font] Link to comment Share on other sites More sharing options...
mmanus88 Posted November 9, 2004 Author Share Posted November 9, 2004 yea i might just go with the kenwood, thanks for the fitting re-assurance! it was just getting a few crappy reviews but i'll probably opt for it anyways. Link to comment Share on other sites More sharing options...
Screaming2.5 Posted November 9, 2004 Share Posted November 9, 2004 There are some things I don't like about how the Kenwood functions. I would like to see more than one line of text at a time and the display is pretty bright, but it does fit nice... Link to comment Share on other sites More sharing options...
mmanus88 Posted November 9, 2004 Author Share Posted November 9, 2004 screaming, did u install it yourself? if so could u give directions on removing the ashtray and fitting it in there? thanks! Link to comment Share on other sites More sharing options...
Screaming2.5 Posted November 9, 2004 Share Posted November 9, 2004 [color=black]It was pretty easy to take the ashtray out, but I have the manual transmission too, so it might complicate things if you have the auto. [/color] [color=black] [/color] [color=black]With the manual, you first unscrew the shifter knob. If you keep the boot from twisting there's no need to separate the boot from the knob. Once the knob is completely free of the shifter, place your hand down into the back opening of the trim that surrounds the shifter (kind of down into the shifter boot so you can get your fingers on the underside of the trim piece. That shifter surround trim is held on in the back by two clips and is "keyed" in front, so if you pull up firmly (with the hand in the back of the boot opening) you can release the two clips that hold the back of the trim piece. From there it takes a little finagling to unplug the wires from the ashtray and get the shifter boot to clear the shifter. The ashtray wires have a standard automotive type plug, so simply unplug. From there the ashtray mechanism is held in from the back by two Phillips screws (one on either side of the ashtray assembly). Unscrew and the ashtray assembly almost falls out.[/color] [color=black] [/color] [color=black]I attached my HU to a piece of Plexiglas using some industrial strength double sided tape (sounds cheesy, but it works and you can't see it). I drilled two holes in the Plexiglas that correspond to the holes that the ashtray used and then used the screws from the ashtray assembly. For +12V constant, I ran a wire over to my fuse box (just used a multimeter to find an always “hot” wire), for +12V acc, I used the ashtray power lead (multimeter again, but make sure you don’t get the one for the light), and for ground, there is a nut/bolt that is down by the shifter mechanism that I used for ground to the body of the car. [/color] [color=black] [/color] [color=black]The only thing to keep in mind when putting the trim back is to keep your wires out of the shifter mechanism when you put the trim piece back, make sure you get the "keys" at the front of the trim lined up correctly, and press the clips back down firmly so you don't get noisy/funny looking trim. Oh, and it's easy to catch the plastic trim on the parking break "leather/cloth/trim fabric" and it will mark it up, so when you put the trim back you might want to try to protect the cloth so you don't damage it. [/color] [color=black] [/color] [color=black]This will all make so much more sense when you tear it apart...[/color] Link to comment Share on other sites More sharing options...
Screaming2.5 Posted November 9, 2004 Share Posted November 9, 2004 The fit is so good without any additional work it's actually hard to believe. I'll take a picture and post tomorrow. Link to comment Share on other sites More sharing options...
Paul G. Posted November 12, 2004 Share Posted November 12, 2004 Any chance of seeing pics, I'm having a bit of trouble visualizing? P. Link to comment Share on other sites More sharing options...
mmanus88 Posted November 14, 2004 Author Share Posted November 14, 2004 yea does not work, try webshots or sony picturetrail Link to comment Share on other sites More sharing options...
Paul G. Posted November 14, 2004 Share Posted November 14, 2004 I use photobucket <www.photobucket.com>. They have 2 levels, the basic is free, and works just fine with plenty of room for your pics. Link to comment Share on other sites More sharing options...
Screaming2.5 Posted November 14, 2004 Share Posted November 14, 2004 [img]http://img.photobucket.com/albums/v520/Screaming25/IMG_0103.jpg[/img] Link to comment Share on other sites More sharing options...
mmanus88 Posted November 14, 2004 Author Share Posted November 14, 2004 wow, perfect fit. good news thanks for your hard work screaming. i'll probably jsut take it to the shop (along with that picture) and tell them to take car eof it. i'm not much of a handson guy :) Link to comment Share on other sites More sharing options...
Paul G. Posted November 15, 2004 Share Posted November 15, 2004 Thanks, now I see what you were talking aboout. Looks real fine, nice work. P. Link to comment Share on other sites More sharing options...
slashie Posted March 26, 2005 Share Posted March 26, 2005 Picture is not showing, Can someone repost it? Link to comment Share on other sites More sharing options...
StringFellow Posted March 26, 2005 Share Posted March 26, 2005 I really like this installation of the Sirius StarBase. I did the same installation and it turned out very well. Close the lid and poof, it disappears. Also it is one of the smallest display units available for Sirius. [url="http://www.legacygt.com/forums/showthread.php?t=9138"]http://www.legacygt.com/forums/showthread.php?t=9138[/url] -S Link to comment Share on other sites More sharing options...
Driver72 Posted April 6, 2005 Share Posted April 6, 2005 Yes, Screaming 2.5, can you please repost the pictures of the Kenwood Ready2Go unit in your LGT. I'm planning on going with the Sirius Starbase in my LGT like Quest did in the above links, but now I want to see your set up first. Thanks Link to comment Share on other sites More sharing options...
