Legacy05 Posted April 23, 2007 Share Posted April 23, 2007 Ok, I am using this picture as reference .. But the would trim piece that runs up the side, I don't know if its the heat or what, but both sides ... make noise. How would I go about getting rid of this noise. If I apply pressure on either side I can duplicate the noise. Thanks. Link to comment Share on other sites More sharing options...
fweasel Posted April 24, 2007 Share Posted April 24, 2007 Ok, I am using this picture as reference .. But the would trim piece that runs up the side, I don't know if its the heat or what, but both sides ... make noise. How would I go about getting rid of this noise. If I apply pressure on either side I can duplicate the noise. Thanks. I used clear bathroom silicone to stop the yellow plastic clips from vibrating and making the noise. When you remove those two pieces of trim, there are three (I think) yellow clips that snap in and hold the trim in place. Even while installed, the clips can still be lose and rattle around. I gooped them up with clear silicone and then reinstalled everything. The silicone isn't acting like a glue, its just insulating the clips so they aren't free to rattle. The trim is still easily removed as this does not interfer with the clips themselves. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
Legacy05 Posted April 24, 2007 Author Share Posted April 24, 2007 So .. you just put the stuff on the outside of the clips and plugged them back in?? Did you put the gunk inside the clip (it doesn't sound like it). Thanks. Link to comment Share on other sites More sharing options...
fweasel Posted April 24, 2007 Share Posted April 24, 2007 So .. you just put the stuff on the outside of the clips and plugged them back in?? Did you put the gunk inside the clip (it doesn't sound like it). Thanks. Yeah, squirted it right into the clips. You need to pull the trim from around the shifter out first to expose two screws at the bottom edge of each piece of side trim. Once those are out, then you can pull up and out on the side pieces. Should be a walk-through in the audio-interior section somewhere... ignore him, he'll go away. Link to comment Share on other sites More sharing options...
Legacy05 Posted April 27, 2007 Author Share Posted April 27, 2007 Did this the other day, and ... it has helped quite a bit! Thanks again for the suggestion. Link to comment Share on other sites More sharing options...
fweasel Posted April 27, 2007 Share Posted April 27, 2007 Did this the other day, and ... it has helped quite a bit! Thanks again for the suggestion. Sweet, glad it worked out. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
iceman Posted April 27, 2007 Share Posted April 27, 2007 What??? Interior rattles? In a Subaru? You gotta be kidding... Goin' to Carolina in my mind...and in my car on the 16th! Link to comment Share on other sites More sharing options...
Hanger Posted April 27, 2007 Share Posted April 27, 2007 mine too but dealer said it won't do anything to them because i'm passed 14k miles? ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
Hanger Posted April 27, 2007 Share Posted April 27, 2007 naw, on mine the piece on drive side rattles like crazy.. comes summer, when it's hot the noise comes back. I think main it's because when i drive, my knee push it down causing it to loosen and rattle. Most of the time i have to use my knee and apply strength on it so it wouldn't rattle anymore. Dealer said i'm passed 14k miles (which covers interior rattling) ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
eL GaTo Posted April 28, 2007 Share Posted April 28, 2007 9700 miles in my '06 and no rattles so far. "Remember..."MODDING is a HOBBY:icon_bigg, not a BAAAD HABIT";) . Link to comment Share on other sites More sharing options...
Hanger Posted April 29, 2007 Share Posted April 29, 2007 oh yea... i'm tall, 6"3' and when i make turns, my knee have no where to go but to press on the trim pieces, and i think overtime it made it to come loose ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
