SoCalGT Posted November 5, 2004 Share Posted November 5, 2004 I've noticed a couple times now that after rain has rolled through it seems that I have an unusually high amount of moisture inside the car. With my old Explorer when everything was shut off no air would circulate through the car, not so with the Sub LGT as far as I can tell. When I shut the heat/AC off I can feel ambient air coming in through the vents. Is there a way to shut the vents so no ambient air can come in? Link to comment Share on other sites More sharing options...
John M Posted November 5, 2004 Share Posted November 5, 2004 Change to recirculate before turning the HVAC off. Every import I've owned let air flow through when it's turned off, while the domestics have not had that happen. Link to comment Share on other sites More sharing options...
Car Dude Posted November 5, 2004 Share Posted November 5, 2004 You can put the HVAC into recirculate when the system is off. The only thing on the display will be the recirc icon. Now if your talking about when the car isn't running, then John M's reply seems logical. Car Dude Link to comment Share on other sites More sharing options...
John M Posted November 5, 2004 Share Posted November 5, 2004 Wow, I've never tried hitting the button while it's off. You learn something new every day! Link to comment Share on other sites More sharing options...
SoCalGT Posted November 5, 2004 Author Share Posted November 5, 2004 Cool, thanks guys :) Link to comment Share on other sites More sharing options...
