Spray Posted April 13, 2007 Share Posted April 13, 2007 Did a search couldn't find anything. I purchased a used AEM cai off a member of the board. I dont have any cleaning solution. I was thinking of putting just a drop of dish soap in a bucket and cleaning it that way. Anyone else have any suggestions? Or should I try and get the official cleaning solution. Link to comment Share on other sites More sharing options...
MonkeyHermit Posted April 13, 2007 Share Posted April 13, 2007 Did a search couldn't find anything. I purchased a used AEM cai off a member of the board. I dont have any cleaning solution. I was thinking of putting just a drop of dish soap in a bucket and cleaning it that way. Anyone else have any suggestions? Or should I try and get the official cleaning solution. Is it the dry filter or the oiled version? If dry I am not sure as I've had no experience with them before, but I guess you can use the cleaning solution that comes in the K&N filter cleaning kit or you can just use water. If it's the oil type filter, get the K&N filter cleaning kit as you don't know what the liquid dish washing soap will do to the filter element (harden it after it dries, shrink it, etc). Plus you would need the oil to re-oil the filter. Or you could purchase the dry filter equivalent from AEM. Hope this helps, I'm sure others will chime in as well. Link to comment Share on other sites More sharing options...
Spray Posted April 13, 2007 Author Share Posted April 13, 2007 It's the dry filter, hmmm I'll try to get the official cleaning solution. Link to comment Share on other sites More sharing options...
MonkeyHermit Posted April 13, 2007 Share Posted April 13, 2007 It's the dry filter, hmmm I'll try to get the official cleaning solution. Just to let you know, I have no experience with the dry flow filters so I take no responsibility if the filter messes up with the solution in the K&N kit You should probably wait for others on the forum to give their input before deciding. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted April 13, 2007 Share Posted April 13, 2007 I would use the AEM cleaning solution. It's not that often that I clean it. http://www.aempower.com/files/dryflow/filtercleaning.html Link to comment Share on other sites More sharing options...
