bernzx Posted November 5, 2004 Share Posted November 5, 2004 I want to do a coolant change on my girlfriends 95 Legacy wagon and I need to know what tool to use to remove the drain plug over by the oilfilter and where to get one? Thanks, bernz(novice Subie DIY) Link to comment Share on other sites More sharing options...
bernzx Posted November 21, 2004 Author Share Posted November 21, 2004 I followed the proceedure in the Chilton's manual and it didn't work, here is what I did. Disconnect the lower radiator hose/thermostat housing( two 10mm bolts, no gasket), pull out thermostat to drain block. To refill coolant, disconnect upper radiator hose from radiator ( loosen hose clamp), pour coolant directly into engine untill full. Replace radiator hose and refill radiator. bernzx Link to comment Share on other sites More sharing options...
