wongmic75 Posted April 4, 2007 Share Posted April 4, 2007 Hi guys, Finally got my aerospats and wanted some advice on installation, the instructions are in japanese and I am not sure if I am supposed to use double sided tape at all? Any one know of a walkthrough on this? I did a search and nothing was found... Thanks Link to comment Share on other sites More sharing options...
lhsa Posted April 4, 2007 Share Posted April 4, 2007 it should come with double sided tape. use that and the existing holes/fasteners. the only snag is the front spats have diferrent hole sizing on the wrap around portion. you can either drill new holes into your body or just use strong 3m double sided tape. i chose the latter. Link to comment Share on other sites More sharing options...
20lgt06 Posted April 5, 2007 Share Posted April 5, 2007 Hi guys, Finally got my aerospats and wanted some advice on installation, the instructions are in japanese and I am not sure if I am supposed to use double sided tape at all? Any one know of a walkthrough on this? I did a search and nothing was found... Thanks i know for my sedan the side pieces are a bit strange to install-- just follow the picture its pretty much straight forward Link to comment Share on other sites More sharing options...
poopy Posted April 8, 2007 Share Posted April 8, 2007 i cut the flap with the 2 holes off with a razor and drilled a srew w/washer in the rear of the front spat. i felt it lined up better that way Link to comment Share on other sites More sharing options...
